Sky InsuranceEM Tuning
    chris039's Avatar
    S3-A quality driving experience
    Worcester
    6
    master cylinder brake hoses
    Hey guys, i recently got a warning light on the dash indicating brake fault, when i checked the fluid it was low and found a wet patch under car, after removing all engine covers ive found a metal coolant pipe has been rubbing on the brake line coming from the master cylinder and worn through it!! my next problem is removing it, it seems to run down and round the back of the engine across the bulk head behind heat deflecting, what a complete ***** to get to, is it goingt o be an engine bay strip down????????
    Dec 2011
    6
    Hi,
    Sorry for the thread revival! Have you had this fixed? I have had exactly the same happen to mine! Nearly killed me. Metal coolant pipe rubbed through the brake pipe that connects to the front of the master cylinder (front = towards front end of car)
    How much did it cost you to have repaired? Going to book mine in at an Audi Specialist, just wanted to check their prices are competitive!
    I ADVISE EVERONE WITH A 8L CHECKS THIS BRAKE LINE IS NOT IN CONTACT WITH THE COOLANT PIPE. COULD LEAD TO SOMEONE BEING KILLED!
    Dec 2011
    6
    For reference, here is a picture of this issue. I urge you to check yours!
  1. Clutch slave cylinder or master cylinder ?
    By ColinS in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2013, 21:29
  2. Replacing the Brake Master Cylinder problems
    By Joe_i in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2010, 18:38
  3. S3 Brake Master Cylinder upgrade
    By Barks in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2010, 08:31
  4. Master cylinder
    By rickparmar in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2007, 19:47
  5. Water under battery tray & brake master cylinder....
    By jrleech in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th May 2006, 06:18
