AH FabricationsVolks Autos
Results 1 to 9 of 9
    Oct 2011
    11
    APU Rods and pistons into an ARY
    Hello all, first post.
    I recently bought an a3 1.8t 180 quattro 6spd which had a knock and blue smoke. I have since stripped the engine out of the car and found that it had spun a rod bearing and as a result the conrod is worn out of round.
    The crank is at the machine shop getting a regrind and the block is getting honed (still within tolerance). The engine is an ARY with 19mm pins however all of the second hand rods that I have seen are from engines with 20mm pins. I am considering some forged items although I have been offered 4 rods and pistons from an APU engine cheap so I am considering taking these. I have been assured that the engine was a good runner and the rods and pistons are good.
    From what I have read the ARY and APU both have 9.5:1 comp ratios. Can anyone confirm if these would be fine in my block or are the pistons different ? (other than they have 20mm pins)
    Thanks for any help
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Should work fine
    TD5 Land Rover Defender build
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,453
    yup, fine
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    With the additional strength of the 20mm pin rods - a fair bonus!
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Oct 2011
    11
    Thanks folks, good to know.
    Apparenty 19mm rods have tangless bearings while the 20mm ones have tangs, should I order bearings for the conrods using the apu code in that case?
    "Stick a V8 in it!"
    14,900
    You want APU bearings if your using APU rods.
    Oct 2011
    11
    Cheers aragorn
    finally (I think), Are there any differences in the piston rings? Will any 1.8t rings fit ?
    "Stick a V8 in it!"
    14,900
    The rings are all the same.
    Oct 2011
    11
    I plan on doing the rebuild this weekend, I phoned my local Audi dealer who can get me the rod bolts however he said that he couldn't see the main bearing bolts on his computer. So does anyone know if a) are these main bearing cap bolts reusable and if not b) does anyone know the part number for them?
  1. N249 Bypass Guide for ARY Engine and all other A3 Engines
    By Syvo in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st November 2013, 14:57
  2. RODS and PISTONS
    By v5 tt in forum TT/TT-S/TT-RS Forum
    Last Post: 21st September 2011, 19:55
  3. ARY and APY are the head the same?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2010, 18:48
  4. How much are a 2nd set of S3 Pistons and rods worth?
    Last Post: 29th November 2009, 23:33
  5. ary max power?
    By marcyp in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2009, 22:15
