Badger5Sky Insurance
Results 1 to 21 of 21
    Kakos_Lykos_rr's Avatar
    May 2010
    9
    S3 8L BAM tuning guide-suggestions
    i want a few suggestions please because i dont know what to do.
    I would like to upgrade my car with some turbos and staff but i do not know much.
    for example i would like to start with engine building changing the oem rods with scat ones but i do not know the dimensions.
    then i would like to change the exhaust valves(8 pcs) with other ones. what should i look what make?
    i will leave the pistons the same but should i change something else?
    after building the engine what turbo must i choose? external wastegate?
    intercooler dimensions? fuel injectors?
    any help is appreciated!!!!
    Tennis,football,basket & golf needs one ball,rallying needs two!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    Before tuning a car you need to know how much power you want and then work back from that...
    Just asking what turbo etc you want is pointless without knowing your power goals....
    How much power are you after and what are you using the car for?
    <tuffty/>
    May 2010
    9
    <tuffty/>
    i want 450-500 horse power and i use the car for travelling purposes.
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,458
    Quote Originally Posted by Kakos_Lykos_rr View Post
    You will need deep pockets
    I find the more power you want more of the none std stuff can't cope
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    May 2010
    9
    Quote Originally Posted by Andrew@A.L.D View Post
    can you please be more specific??
    colicabcadam
    sell and buy an s4 / rs4 or s2 / rs2 if you like old school, you'll spend thousands and get none of it back
    if you are doing it as a hobby then do it, but good luck getting 450 bhp out of it without spending the value of the whole car again
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    Basically for that kinda power you are looking at something like a GTX3071r or GT3076r turbo...
    You will need to change the rods and rebuild the head using uprated valves and springs etc
    Parts wise...
    Turbo (GTX371/GT3076)
    Tubular exhaust manifold
    External wastgate (tial)
    3" DP and exhaust system
    Large FMIC (AH Fabs or modified toyosports)
    Supertech valves and springs
    AEB/AGU large port head
    Rods
    Big end shells
    Larger injectors
    Inline fuel pump
    Custom TIP to suit turbo
    plus various other pipes and hoses etc... custom water pipes and oil drains etc... extra heatshielding
    And not forgetting a custom map
    As Andrew and others have implied... the cost of the hardware is expensive enough and then factor in labour and all the fabrication then you are looking at quite a large figure...
    Really does depend what you want at the end of teh day... both Andrew and I have gone big turbo but we have done the work ourselves so there are cost savings and I personally am not the sort of person that buys a faster car when I want more power....
    However there is a lot to be said for buying something more powerful out the box colicabcadam has 'suggested'... a fellow member and friend has done similar and bought an RS4...
    There will always be people that prefer to upscale to get the power and those that enjoy getting the most (even if it costs alot) from what they have...
    Either way budget anywhere from £6000 upwards....
    Useful links...
    Lots of Big Turbo and High Power info!
    Lets get it on then, My 2.1 conversion
    My minor modding thread
    There are others here of course so have a search
    <tuffty/>
    colicabcadam
    i think tuffy hit the nail on the head
    be prepared to loose money or be prepared to hang onto the car for a long time, spending £6,000 on the car will not make it worth a penny more and in some cases it can make it harder to sell too
    if you buy a more powerful car, you'll loose a LOT less cash in the long run
    the cost of an s3 plus £6,000 plus a little bit more cash can get you a very nice rs4 which will loose a little if not no value at all
    you can pick them up with 450/450 already, i choose to go standard (380/325) because the car i saw had all the expensive components recently changed (brakes all round, clutch, cam belt, tyres)
    like i said, if you are doing it as a hobby do it, you'll enjoy it! however, if you just want a car with 400 bhp you're going the wrong and expensive way around it!
    Jun 2009
    Leeds
    3,458
    Parts wise...
    Rods
    Big end shells
    Larger injectors
    Inline fuel pump
    Useful links...
    <tuffty/>
    I don't need to say anymore as its all there /\ /\ /\
    FOR SALE
    Jun 2009
    Leeds
    3,458
    Also forgot you will need better brakes and some sort of coilover kit
    My brakes cost me £1500 all round so you will have to add that to the list
    FOR SALE
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    Good point... easy to forget getting the stopping and chassis in order...
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    <tuffty/>
    Have you mentioned this to Welly.....
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    Welly is a special case... very special!!
    <tuffty/>
    May 2010
    9
    my car has already installed bilstein pss9 8 months ago.
    here in greec is difficult to change to bigger engines as the taxes are too many so i have decided to stay with 8L S3. thus i decided to upgrade the engine. otherwise i would change it with rs4 easilly.
    staying with the same car i want something more of it and i will fix it alone as a hobby but dont want to spend all this cash.
    if i change only conrods and external valves for the engine can i get to 450 horsepower without trouble?
    rods what make do you suggest? scat? IE? do you have links maybe? should they be riffle drilled??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    IE Con rods on std pistons will be ok for 450bhp... rifle drilled will make sure oil gets to the little end bearings... with big turbo power you would need to change the valve gear to supertech really and make sure you change the exhaust valve guides as these wear from relatively low mileage...
    What I listed in my post still stands... that is the minimum kit you will need to get the power you want... you will save money by doing the work yourself...
    For prices try INTEGRATED ENGINEERING Forged VW/AUDI Connecting Rods, JE, Wiseco, Mahle, Ferrea, Supertech, ARP and ATP TURBO - The Premiere Provider of Turbocharging Components
    You don't need to use a tubular mani which is more expensive but you will need external gate...
    You could also try something like this...
    Audi TT225HP / Audi S3 Quattro Big Turbo Kit: CTS Turbo
    Badger 5 is using this kit for a TT due in Christmas time using a GT3076r
    <tuffty/>
    May 2010
    9
    i will change only the exhaust valves or do i need to change all of them?
    exhaust valve guides i will change for sure which make to choose? oem i think that you cannot buy is it true?
    so you suggest riffle drilled rods? do you have a link from eu? not us? because i will pay customs if i buy from us.
    warren_S5's Avatar
    Oct 2007
    7,135
    Weh-hey, really pleased to see you guys in Greece are still modding given the international news we get here in Britain! Our media tell us your financial crisis is so bad you'll be selling your own kids for medical research just to eat and keep warm!!!
    Understand the situation with the tax, but getting a daily driver to this kind of level will be a significant ongoing challenge. Do yu really need 500bhp? You could do something more sustainable and save yourself a lot of money and still get close to 400 with a BT conversion and maybe a WMI set up? (Seen a few daily driver Leons running this kind of power on another forum without too much trouble).
    Whatever you do, best of luck, and plan it carefully to make sure you go on the right journey.
    Audi S5 3.0V6T Coupe Black Edition
    May 2010
    9
    Quote Originally Posted by warren_cox View Post
    thanks man i am thinkng 400 horse power and at most 450. i think that is will be not much trouble...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    Change all the valves and springs... I have these..
    Supertech 1.8T 20V Valve Spring/Titanium Retainer Set
    Supertech 1.8T 20V Intake Valve Set Single Groove
    Supertech 1.8T 20V Exhaust Valve Set INCONEL Single Groove
    Replace just the exhaust valve guides as these are ones that wear... you will need to get this done by an engineering shop... I would look for a large port head though to replace your small port one and build that... use your cams, followers and VVT tensioner...
    Yes, use rifle drilled rods if you can stretch to that...
    Bill at Badger 5 can get this stuff but he gets his gear from the US too so they will still end up costing the same... the choice is yours of course..
    <tuffty/>
    Jun 2009
    Leeds
    3,458
    What about the clutch?
    Badger5 again for that
    FOR SALE
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    Fair point well made
    <tuffty/>
  1. EM Tuning VAG Panel LED fitting guide..
    By t8ups in forum Tech Support
    Last Post: 10th January 2014, 14:03
  2. 2.0 TDI BKD tuning suggestions - PD170 Turbo retrofit?
    By VAG_BADGER in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th December 2013, 13:51
  3. Definative tuning guide?
    By Rough in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2010, 18:05
  4. RNS -e How to guide to install guide and advice
    By 330_2_S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd April 2009, 15:15
  5. Audi A4 1.8T Tuning Guide
    By billybravo in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th August 2008, 22:40
