Chris NottBadger5
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    692
    VCDS Auto Scan Log
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
    Address 01: Engine Labels: 06A-906-032-AJQ.LBL
    Controller: 8N0 906 018 BH
    Component: 1.8L R4/5VT 0001
    Coding: 10710
    Shop #: WSC 02629
    VCID: 78836BE34BDD
    WAUZZZ8L231203225 AUZ7Z0B2120923
    1 Fault Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: Redir Fail!
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    VCID: 3E0FBDFB2979
    1 Fault Found:
    00812 - Brake Pressure Release Solenoid (F84)
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    692
    Any help with these fault codes would be appreciated.
    [8L BLOG] [8P BLOG]
    S3 Paul's Avatar
    Oct 2006
    2,764
    First is... one of a few...
    Battery terminal has been off or... is loose
    Battery is on its way out,
    If you remove the battery the car will always log the low voltage code...
    Second code im not so sure of,
    I work by the rule... read the code, write it down. clear it from thr car and drive for a week or so then rescan , if the fault is back... worry, if not happy days
    Noggy Blue 2001 S3
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    As above on the first one..
    the second one is usually a brake switch fault, do your brake lights work ok?
    As paul said clear the faults (as they could be very old) and recheck after a drive/day or 2
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    692
    Thanks for the advise. My brake lights do work.
    I'll clear the codes and re-check in a week.
    [8L BLOG] [8P BLOG]
  1. VCDS log - Take a look?
    By Stanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2011, 21:24
  2. VCDS scan - where?
    By Simon S4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th February 2011, 20:25
  3. Mates Mk5 Golf wont start and VCDS wont read anything on the auto-scan ??
    By sc00byd00byd00 in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd February 2011, 11:35
  4. Help with VCDS scan
    By fad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th December 2010, 01:09
  5. My First VCDS Scan
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2009, 22:23
