AH FabricationsEM Tuning
Results 1 to 8 of 8
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    New Member - new car.. new issues... Head Gasket Going?
    Hi All,
    I have been searching and searching for my first car for months now, finally I chose the A3 1.8T. When I went to look at the car, there was no obvious problems, checked coolant, oil and the whole lot, seemed very tidy and checked out okay with my friend who was a lot more experienced than me...
    So... I have had the car a week today, the engine light came on... I took it to get diagnosed and seems a thermostat is faulty for regulating the water to the rad.. anyway... that problem in the process of being fixed, I get home and check the coolant again... there seems to be a yellowy foam forming on top of the coolant which has turned a bit milky... there is no change in the oil though, that all seems to still be fine.
    Lets just say it is not the HG, what other problems could cause something like this? Ive got it booked in for a compression test next tuesday but I cant stop thinking of the problem and what it could be... I have been reading up on the forum for hours now and there are so many happy endings when it comes to this issue that im hoping my problem isnt the HG!!!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Theres no point speculating mate, get the tests done, hopefully it will be ok....it could just be poor maintenance from the previous owner...
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Cheers for the speedy reply, Ill try not to loose too much sleep over it! but.. What kind of costs would I be looking at for a HG and fitting?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    change coolant. take the tank out, clean it out. fill up again. then monitor it from there
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Thanks a lot, as soon as I have fitted the new thermostat Ill flush the coolant and give the tank a good clean. Will the compression test tell me if there is a problem with the HG or does it only tell you if it is completely gone? I was wondering if it was worth shelling out for the test?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    it'l tell you if there is any loss of pressure in each cylinder and will indicate either HG, or head problem.
    im unsure of how much they cost tbh so dont know if its worth it. but seeing as you need to change the thermostat (horrible job), you may aswell take the tank out and clean it and refill with new coolant and water, then monitor it from there. thats what id do.
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    cheers for your recommendation! Ill do it over the weekend when Ive got some time!
    Wind Deflector Trend-setter
    Nov 2011
    Horsham
    386
    As above approach constructively and don't worry about it - If it's a problem then it's a problem, but at the moment it's only a hunch
    2000 Plate Audi S3 1.8T Santorin Blue - 275BHP on Custom Parsons Performance remap, Forge 007p DV, Red DogBush, Milltek non-res, Lowered 35mm Apex springs, Badger5 TIP/cone filter/heat shield, Powerflex'd, Large FMIC, Relentless Downpipe, Parsons Decat and lots of love.
    On gearbox number 4.
    Further modification to come..
  1. Possible Head Gasket / Cracked Head Problem?
    By Wabby in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th February 2013, 14:31
  2. S3 head gasket issues?
    By darkfibre in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2010, 16:07
  3. Issues post head gasket
    By jimmernet in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2010, 12:58
  4. Head gasket/ cylinder head worst nightmare!
    By lugz in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2010, 15:52
  5. Car serviced by Audi just over a week ago now I have a blown head gasket! PLEASE HELP
    By Solani in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2008, 07:04
