Press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
when i put in the code for speed (17), the reading comes out in kilometeres, is that standard or does any one know how to change it to standard m.p.h ?
Also when i switch the engine off it reverts back to the original setting of 1c.
