Thread: braking noise
    imported_Nigma
    braking noise
    I've started noticing a grinding noise when applying the brake pedal after starting the car. It pretty much disapears after two/three presses of the brake. The brakes and pads look ok to me.
    Any thoughts?
    Anand
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: braking noise
    Most likely to be a small amount of rust build up from overnight parking. Obviously happens more in the winter.
    Check the thickness of the brake pads, but this shouldn't be anything to worry about.
