Badger5AH Fabrications
Results 1 to 34 of 34
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Engine rebuild advice needed
    As some of you may know, I've got to replace the engine in my S3.
    Now I'm picking up a AGU engine thrus/fri this week & as soon as I've got it home its coming apart to be checked over etc
    My main question is what should I do with it in terms of upgarding things (internals)?
    My list so far is forged con rods, but I'm not sure if there is any thing else I should do?
    Pat
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Rods are the main thing they are defi nately a must if tuning and putting more power through the engine
    Exhaust valve guides are worth doing in the head as they can wear quite a bit
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    beachbuggy's Avatar
    Surrey
    1,745
    You'll need to change the big end bearings anywAy as you're fitting rods. Well worth changing crank bearings as well. Also it was me I'd change the oil seals at both ends of the crank. Not heard of them failing but better to be safe than sorry. Also get a new oil pump and oil pick up. Agagain pump not exactly necessary but well worth it and pick up is a must. New piston rings on the old agu pistons and you'll be good to go.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    may as well do the rings and hone the bores when its apart tbh.
    Get the valve guides checked and replaced if needed and have the valves lapped in.
    Replace the oil pump too.
    TD5 Land Rover Defender build
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Thanks, I'll get a list together then I'll post it up to see what you think.
    Pat
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,281
    Get the head checked over. Pressure tested and skimmed if necessary.
    I'm rebuilding my engine in the new year so i'll be keeping an eye on this thread.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Hello again
    I went on a bit of a road trip last night & picked up an AGU engine which I won on ebay.
    The bloke I got it from was sound & I had a good old chat (like you do) with him, as he is well into his VAG's.
    anyway....
    He gave me a few extra bits & bobs which are of no real use to me, but I took them anyway
    But one of the bits was a solid flywheel, he told me that it's a G60 ABF flywheel!
    Which if it is could I use it?
    Pat
    beachbuggy's Avatar
    Surrey
    1,745
    Yes I believe you can use it called a solid mass flywheel, used as an upgrade to dual mass flywheel. Maybe worth getting it refaced though just to be sure it's ok, well worth fitting though.
    Westy's Avatar
    Dec 2008
    17,281
    Good work. I managed to source an AEB head recently too. What are your plans for the engine?
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Quote Originally Posted by pats3poa View Post
    ......But one of the bits was a solid flywheel, he told me that it's a G60 ABF flywheel!
    Uses a 228mm clutch plate vs the S3's 240mm so not a straight swap... not seen it done on an S3 tbh as the clutch is smaller... depends what you want I guess...
    <tuffty/>
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Quote Originally Posted by ;1413002
    <tuffty/>
    Thanks for the info, so it's a no no.
    Never mind, I'll put it on the bay with the rest of the bits
    Pat
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Quote Originally Posted by Westy View Post
    I'm going to do a full strip down & rebuild, full head service & bottom end forged rods etc.
    I'm trying to put a list of parts etc together so you guys can have a look over.
    I know one thing the misses isn't going to be happy if she see's the prices, so we'll keep that on the low yeah?! Lol
    Pat
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    ....I know one thing the misses isn't going to be happy if she see's the prices, so we'll keep that on the low yeah?! Lol
    Pat
    I hear that brother!!...
    <tuffty/>
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Pat
    Know that feeling misses is at the last thread with costs on mine keep promising to save for a house lol
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    Pat
    Amen...!
    Audi S3 1.9 GT30....
    ....that is all
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    LOL great stuff!!
    Ok heres my list of parts for you guys to have a look at, add to the list if you feel I've missed anything
    Complete Gasket Set
    Head bolts
    Valve oil seals
    Forged con rods - Hopefully already sorted
    Piston Rings
    Wrist Pins
    Crank bearings & big end bearings
    Water pump
    Oil pump
    Cam belt kit
    Spark plugs
    Clutch kit
    Engine oil
    If you think I should add or take off anything say, as you guys know the in'n'outs!
    Just a thought........ but should I think about a hybrid turbo now?
    Pat
    RIP S3dave
    May 2004
    nr Glos
    7,183
    Pat
    G60 flywheel is for 228mm clutch, your std clutch is 240mm
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    "Stick a V8 in it!"
    15,385
    I didnt bother touching the wrist pins when i did mine.
    Used the original pistons and pins, and new brute rods.
    You'll need to ask around and find a decent reputable local engineering shop.
    You'll want the bores checked and if within tolerances honed. My block had a ridge on the cylinders, but the bores were still within tolerance, so i just had it honed and reused the original pistons. If they're out of tolerance you'll have to rebore and go for larger pistons. I also had the block face skimmed very slightly to ensure a perfect seal on the new headgasket.
    With the head i had it lightly skimmed to ensure it was flat, washed heavily as it was caked in sludge, then i had the valve guides checked and the stem seals replaced.
    From memory, i paid around £100 for the block prep and about £150 for the head work.
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Thanks bill, I was going to send you an email about an hybrid ko4, but as you popped in what do you think?
    Pat
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    ^^ thanks for the info, I will be getting everything checked over.
    Lol there's not going to be any "it'll do" round here, if it needs sorting - it'll be done
    Pat
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Pat
    Amen....
    Westy's Avatar
    Dec 2008
    17,281
    Cheers for the list matey. It's not a cheap job if you want to do it properly, even if you do all the work yourself and save on labour.
    S3 Build Thread
    Sep 2010
    Devon
    756
    Honestly darling it only cost £20 on ebay..... Its amazing what you can get! Done me good for a couple of years now. Pat where are you based in Devon?
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Quote Originally Posted by slowcoach3 View Post
    I'm in Exeter, were abouts are you?
    Sep 2010
    Devon
    756
    Mortonhampstead but I work at the Rusty Bike in Exeter so I'm in there everyday. I'm running late actually playing around on here when I should be in my kitchen! If you ever need a spare pair of hands I'd be more than happy, running out of things to do on my A3....!
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Cheers dude that's good to know!
    Do you go down maccys?
    Pat
  28. #27
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    I haven't even priced any of it up yet, I've got one hell of a sweat on just thinking about it! Lol
    No, really it's got to be done properly as it would be easy just to put the AGU lump in as it is & drive, but knowing my luck with the car so far it would go bang on the way home!
    Pat
  29. #28
    Sep 2010
    Devon
    756
    I've never been down to maccys, didn't know anyone and had the impression it was for the younger generation ( corsa crew) if there is some VAG boys i'll make effort! God that sounds really bad. Sorry!
  30. #29
    Aug 2010
    bradford
    1,252
    I picked my agu head up last Saturday got it for 70 got price and in great nik too sending it to drakes enginers should cost me about £160 for everything doin like but be werth it.
    The cams I have In mine now are worn and have marks so want to get it off looks like oil starvation or something from preveas owner just my rods now and I'll be on with my build
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
  31. #30
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    I was just asking as I would have popped down in my misses car, always full night times tho!
    Have seen a few VAG motors about!
    Pat
  32. #31
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Quote Originally Posted by s3gazz View Post
    That isn't a bad price £160 for a head service!
    I remember on a C20LET head a few years back it being best part of £200 +vat!
    Pat
  33. #32
    Aug 2010
    bradford
    1,252
    I no pal well chuffed with it cannot wait to start it all after Christmas
  34. #33
    Sep 2010
    Devon
    756
    Don't want to derail your thread but I'll make the effort to sort my work/life balance out and get down there, it would be good to meet up with some fellow audi tinkerers in the area!
  35. #34
    May 2011
    Sunny South wales
    82
    Forgot to add at least 2 or 3 oil filters (and lots of oil) and a new oil cooler.
  1. engine management light on advice needed
    By daren in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th December 2012, 18:44
  2. Engine Conversion advice needed pls!!!!
    By royce259 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2009, 21:19
  3. Advice needed on 2.0Tdi engine
    By WKDLAD in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th October 2009, 17:03
  4. Engine transplant. Advice needed
    By shaz-raul in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th September 2009, 10:51
  5. engine problems advice needed
    By 20s on a tt in forum TT/TT-S/TT-RS Forum
    Last Post: 31st March 2008, 10:26
