AH FabricationsBadger5
Results 1 to 8 of 8
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    Grinding noise when steering left?
    ive noticed that recently ive been getting a grinding noise only when steering left round a corner, as far as i know it doesnt do it when stationary just when the wheels are in motion, ill have to have another check to be 100% tho.
    any ideas???
    S3 OFU
    May 2011
    West Mids
    86
    I had the same symptoms. Turned out to be the CV joint, probably worth a look
    colicabcadam
    95% cv joint - cheap fix - might as well do them both (left and right)
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    cheers guys... dya rekon there easy to replace yourself or is it a garage job
    colicabcadam
    you could do it yourself - but tracking MAY need to be done after which you wont be able to do..... i'd do it yourself and get the tracking done if you feel it;s out afterwards
    do you feel the grinding through the steering wheel?
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    no you cant feel anything really its just the noise, sounds like to peices of steel rubbing together or sumat like that, like when something needs oiling if you get me
    colicabcadam
    usually with a CV joint you'd get some kind of feel through the steering wheel - it could be the brake shield rubbing on the discs....
    just get the car up in the air and have a look
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    Ok buddy thanks for the info I'll have a good check over the weekend
  1. knocking and grinding noise on left hand bends
    By wickyianr1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th October 2010, 21:13
  2. Problem number 1 of ownership! Grinding noise and knocking noise help!!!!
    By gaznogaro2003 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2010, 09:17
  3. Too much of wind noise in cabin and grinding noise on start up
    By Neesh in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2010, 08:49
  4. Replies: 10
    Last Post: 23rd March 2010, 15:20
  5. A load noise in when turning steering wheel left of right
    By howard in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2006, 13:08
