Badger5Chris Nott
Results 1 to 15 of 15
    Yohan87's Avatar
    May 2011
    404
    AMK ECU Diagram - Secondary Water Pump
    After dropping an AMK in to a Bora 4motion it appears the wiring for the secondary water pump is not on the engine loom for the S3 so I'm assuming it's on the other one.
    Unfortunately the Bora doesn't have this on it's other one so I will need to run a cable to the ECU.
    I believe the ECU supplies the live for this pump for a certain time period after engine switch off to reduce hot spots.
    Does anybody have a wiring diagram that would let me know what pin on the ECU I'm aiming for?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Are you sure? I was under the impression the fan controller was responsible for the after run pump... IIRC, after run pumps weren't fitted to a lot of VW 's...
    I have the ecu diagram for the AMK somewhere so if I get time tonight I'll have a look...
    <tuffty/>
    Yohan87's Avatar
    May 2011
    404
    Pretty sure.
    The Bora V6 engine didn't have this feature as standard so when I fitted the S3 engine will all its bits I was left with an after run pump but no connections to plug in to it.
    Now that I have it I wouldn't mind using it since these 1.8T's get quite toasty even in Aberdeen...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    <tuffty/>
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    I wish i could add one to mine as easily.
    Yohan87's Avatar
    May 2011
    404
    Awesome, thank you
    So assuming I'm reading the diagram correctly..
    The -ve connection is switched from a relay in the coolant pump control unit which turns the pump on/off.
    What does this control unit look like?
    To answer my own question...
    Audi Vw Radiator Fan Control Module Unit , Controller 1J0 919 506 K | eBay
    Looks like I need to get myself one of these and just run the wires needed to the ECU and away I go.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    A bit like....
    <tuffty/>
    Yohan87's Avatar
    May 2011
    404
    Final question then..do I need to buy special crimps to plug wires in to the ECU?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    When I did my cruise control the ECU plug had the connectors (uncrimped) already in there... yours may have too but if you have the loom off the S3 then you could just cut the wires from that as tails and solder the new lengths to them... in answer to your question, you can only use special crimp terminals for the ecu... not sure what they are called or where you can get them from but somewhere like RS Components etc may have some if you can't find any already in the ecu plugs or use tails from the other loom...
    <tuffty/>
    Yohan87's Avatar
    May 2011
    404
    Thanks for your help Tuffty.
    Apr 2004
    12,521
    So it's a stand alone controller, no connection to the ECU, tidy
    Yohan87's Avatar
    May 2011
    404
    I think it does have a connection to the ECU, I think the ECU passes a signal so it knows for how long to run after your turn the engine off, based on temperature?
    Apr 2004
    12,521
    yeah i assume connection 60 is it... Maybe i'll get some kind of timer relay made up, can't be that hard.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    The S4 uses a similar controller, and its nowt to do with the ECU.
    Its triggered by a second temperature sensor mounted in the coolant rail.
    That diagram doesnt seem to match the picture shown. Pic shown has many pins, the diagram doesnt.
    TD5 Land Rover Defender build
    Apr 2004
    12,521
    So i need an S4 controller then?
  1. Secondary Water Pump No Working
    By Inertiauk in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2011, 07:59
  2. Vaccum diagram for amk s3
    By dribz-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th June 2009, 23:10
  3. Aux Water Pump Leaking - S3 AMK Engine
    By jimbo_123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2008, 17:39
  4. Secondary water pump on 3.2?
    By Wes G in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd October 2007, 17:47
  5. secondary water pump problems
    By stevegti6 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th July 2007, 07:42
