Results 1 to 16 of 16
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Quick advice needed please
    I was just about to go and inspect the passenger side leccy window just to find out what the problem is. Last week I opened the window and when I tried to close it the window came up a couple of inches then went back down. Im assuming the clip may have broken but do I take the doorcard off to inspect it with the window up or down ?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,924
    Door card will come off with up or down
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Cheers buddy
    It would be easier if I can inspect the problem with the window up for obvious reasons but is it more advantageous up or down ?
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    If you plug the switches back in when the door card is off, you can move the window up/down
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    You need the window half way up to see/inspect the window clips, with the door card off, I just stuck my carkey into the door lock to wind the windows up and down, but it does both sides this way.
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Thanks guys
    Ive taken the door card off to have a look but cant see anything obvious. Nothing appears broken looking at the clips and feeling around the back of them. I put the window down which it does no problem but wont go back up unless I shoved the window from underneath. It seemed as if the motor was struggling to push the window back up so I sprayed the runners with WD40 but of course you can only spray one side of the runner but it didnt seem to make a lot of difference. Unless I take the door frame off I guess I wont be able to see what the problem is. The only problem is though it looks like you need a large torx bit which I dont have.
    Does this sound like broken clips or a liberal greasing of the runners is needed ?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    if it closed up. then came back down a bit it means the window thinks there is something trapping it.
    clean the runners and door frame where the window goes into
    should fix the problem
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    The window drops all the way down then will only come back up 2 or 3 inches before dropping back down again.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    If you've not seen it already, this is the guide for the clips:
    Audi A3 Electric Windows Fix
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Quote Originally Posted by jcs356 View Post
    Cheers Jason
    I have seen that guide its very good and pretty much describes what I am experiencing. Just an update I have had the doorcard off again and greased the hell out of the runners but its still sticking. I think it will be a doorframe off job and replace the clips but does anyone know what size torx bit is needed to get the frame off ?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    Actually from past experience, the broken part can't be seen unless you have done it before, as it's facing the outside where the wires are clipped into the plastic clips that break.
    a3tdi2001's Avatar
    437
    Is the cable all intact? It had snapped on mine giving the same problem as you have got there.
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Quote Originally Posted by a3tdi2001 View Post
    I didnt see any broken cables but I could have missed that I suppose.
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Guys can anyone advise what Torx bits I will need to do the job please ?
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Bump
    Anybody please ?
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Only thing I know the Halfords Pro 7 piece Torx set has the right size in it.
    Jason
  1. Quick bit of advice needed.
    By SamiG in forum VCDS (formerly VAG-COM) forum
    Last Post: 1st December 2010, 14:07
  2. advice needed quick plz!!
    By nath-w in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2010, 23:04
  3. QUICK QUESTION...QUICK ANSWER NEEDED!
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2009, 16:33
  4. Low Oil - Quick advice needed
    By spiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2007, 20:57
  5. A3 Quattro FK Highsport - Advice Needed Quick!
    By SyA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2006, 15:53
