    Apr 2011
    Clutch issues....
    From doing a bit of forum searching, it seems the clutch slave cylinder is a bit of a common arse hole
    Earlier on today, my clutch decided that it wanted to play up - I can just about change gear when the clutch pedal is pressed flat to the floor, am i right in thinking that this is down to the slave and not the master cylinder?
    Also, about 3 hours after this happend I started to get a ticking sound that dissapears when I put the slightest amount of pressure on the clutch pedal....is this down to the same thing?
    Cheers lads,
    Mike.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    pedal to the floor is typically the master cylinder...
    <tuffty/>
    Apr 2011
    Is the master cylinder on the pedal? Or housing?
  1. 1.8T gearbox/clutch issues?
    By eddieantifreeze in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2011, 15:25
  2. Gearbox / Clutch issues?
    By trailer in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2011, 17:29
  3. S3 remap clutch issues?
    By nicks3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th October 2009, 22:59
  4. s3 clutch issues
    By S3Matt1983 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2007, 19:51
  5. Clutch Master cylinder issues.....
    By nlw73 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 08:59
