Hi Guys hope somebody can help with this one, in the last week my S3 has failed to start on a couple of occasions, evntually It has started but the problem is that the fuel pump is not starting up as you can't hear it purge, the first time I got the rac out and he jacked the car up and hit the petrol tank and car started, the guy said the fuel pump was sticking. 3 days later I had the same problem so I jacked the car up tried hitting the fuel pump several times but no joy and the battery was starting to go down after all the none starts so gave up, after 5 minutes sussing out what to do I tried to start again and it fired straight up.
Has anyone had this problem ifso what was the cause I'm hoping it might be a dodgy relay but knowing my luck it will be much more expensive.
