AH FabricationsEM Tuning
Results 1 to 16 of 16
    Jun 2011
    249
    side skirt (door blade)
    hey guys you know the Grey part below the door (side skirt), is starting to peel off,
    what would i require to get it back? so everytime i close the door it stays in place.
    thanks Dre
    A3 S Line 2.0 TDI Sportback - DSG
    BOSE, cruise control, bi-xenons, MFSW, Heated seats, paddle shifts, ipod connection
    19" Speedlines | Reverse camera | Eibach Sportline Springs | MY09 LED Tails | Eibach Spacers Front 10MM Rear 12MM | Pioneer HU | Private Plate | Tints | LED numberplate | Interior Light Kit
    Jun 2011
    249
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,883
    2 options, take them off and repair them before putting them back on or buy new ones which are £120+ each!
    I've put a new one on my driverside which cost me £80ish some 5 years ago, they have gone up in price. I've repaired my passenger one in the past, but it's coming apart again.
    Oh, and we usually refer to this part as the doorblade.
    You've got to have a laugh!
    Jun 2011
    249
    how would i repair them if i take them off? ah thank you jojo
    also do u have the part number to call up dealers regarding prices! :P
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,883
    Below is a knackered(my) one.
    It should like like this
    Basically, the white nylon bit is pushed into the rubber bit, but over time, the rubber part shrinks and the nylon bit pops out. A quick fix is to push the nylon bit back in and araldite it, but it's a temp solution, it will come apart again over time, and in my case, 4 years or so on the passengerside.
    Don't have the part number on me, as I'm currently at work - Sorry.
    New one fitted as supplied out the box.
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,177
    I've bought a full set of used blades and will be replacing my passenger side one which is starting to come away (not as bad as the pic above). I've decided that I will discard the original screws and bond it to the door (using this: Sikaflex Adhesive (Black) - Performance Car Parts / Car Accessories / Car Tuning / Car Styling / Essex - Rude Racing), which should also seal it and prevent water from getting in between the nylon & rubber sections.
    Jun 2011
    249
    you dont have a picture so i can see where it clips into how does it look without the door blade?
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    The blade is positioned on 4 pins i think and then the blade slides forward to lock it into position . If you look at the picture Jojo posted you will see the groove on the back of the blade. Removing the blade would expose the pins and the bottom of the door so I wouldnt recommend removing them.
    Ive replaced the drivers side one. Bought a used one off ebay and then had all 4 colour coded to match the car, looks good on black.
    Cheers.
    S3 Big Turbo
    Jun 2011
    249
    i was looking at mine earlier and noticed that the white nylon is stuck onto the door but not the side skirt ive tried using adherive from halfords looks like its replacing anyone got part number?
    Jun 2011
    249
    i was looking at mine earlier and noticed that the white nylon is stuck onto the door but not the door blade is starting to come off the white nylon ive tried using adherive from halfords looks like its replacing anyone got part number? im going to try taking it off and fixxing it because the white nylon doesnt seem worn
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    458
    I have just fixed my door blade. I tried using super strong grab adhesive as it was peeling at the end of the door (nearest the door handle), and it held it on for about 6 weeks but then came away. I decided to then get one from a scrappy but they send me the wrong part so I sent it back and coughed up £130 odd for the part from the Stealers.
    If you get a new one, you will find that the part is UN-PAINTED!!! It will be primed and will look a very pale grey in colour. If you want it to look half decent, you'll need to get it painted by someone. I got my mini rear door blade painted at the same time so that they would match in colour. I went for a matte lacquer so that they weren't as shiny as before, but now I need to get the other side done because the new side looks so nice, and the other side is scuffed, old and battered! As you can see, the new part fits perfectly and only took 5 minutes to put on.
    Before:
    After:
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,177
    What adhesive did you try?
    Jun 2011
    249
    Quote Originally Posted by The Doctor View Post
    i used Araldite Precision Syringe Halfords | Araldite Precision Syringe.
    i would push it firm for about 10mins to hold but it wouldnt it will just come back to normal loose position. also the nylon doesnt seem damage/worm as much as the pic before is just the doorblade is loose from the nylon bit but nylon is still screwed on firmly.
    Jun 2011
    249
    called up audi and they said its £156 for doorblade
    for a doorblade. could upgrade brakes with that.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,883
    Unfortunately, the best way to repair these is to take it off the car! Doing it in situ will not last long I assure you!!
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    458
    Yes....definitely repair these off the car. Unfortunately I couldn't get mine off the door without trashing the strip. All you need to do is glue the nylon runner back into the recess on the rear of the door blade.
  1. 3 DOOR- A3 8P S- line rear Valance and side skirt parts
    By Audi-Rog in forum For Sale/Wanted - Audi Parts
    Last Post: 7th April 2013, 12:27
  2. NEED a b7 black s line right side side skirt! anyone got????
    By andia4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th September 2010, 13:24
  3. votex side skirt help
    By MAD_Adamski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st September 2010, 16:52
  4. Wanted - Passenger door side skirt
    By Tom Mineral Grey S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2010, 22:19
  5. Wanted - Passenger door side skirt
    Last Post: 4th April 2009, 00:07
