Chris NottSky Insurance
Results 1 to 13 of 13
Thread: S3 Coilovers
    Oct 2011
    Whitby
    27
    S3 Coilovers
    Hi,
    bought an 8l s3 a while back and just recently fitted some coilovers (diy job), c.v. boot was knackered so took it to the local garage and they fitted a new one, whilst it was in i asked them to check the coilovers, they said all seemed fine so I've been driving it normally.
    There are a few knocks and creaks when driving slowly or reversing, deffo knocks when in full lock.
    Is something wrong or am i just being paranoid????
    Haven't had chance to get a 4 wheel alignment done yet and also need to buy some adjustable tie bars coz the camber on the back is ridiculous, dunno if this has anything to do with the knocks and creaks.
    Would massively appreciate any help.
    cheers.
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,899
    Visit 16Klappe's Instagram Channel
    Have a look at the top mounts and ARB bushes would be my recommendations.
    I quite often say I'm going to do things.
    Then never do them.
    Oct 2011
    Whitby
    27
    Checked them, all fine.
    Could it be they are just **** quality coilovers?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    How have you checked the top mounts? Take the top mount trumpet it off and see if the nut style washer is tight, more than likely itll be loose and causing your knocking, mine was and sorted in yesterday, no more knocking now :0.
    JtotheD's Avatar
    Events Moderator
    May 2011
    Bournemouth, Dorset/ Wallingord, Oxon
    907
    what coilovers are they out of interest?
    S3 8L Ming Blue 273bhp & 294lbft h
    Build/project thread
    check it out!
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    I doubt it will be the quality of the coilovers, if it is just a knocking it is probably not.
    A slow or too fast rebound, sloshy or harsh ride combined with knocking would suggest shocks. Knocking on it's own suggests top mounts of a bearing/bush. Have you checked the drop links?
    Then never do them.
    Oct 2011
    Whitby
    27
    they were FK ones, they were like £300 so probs just need to get some decent ones, any recommendations??
    checked them by doing exactly wot u said mate, all seemed fine.
    JtotheD's Avatar
    Events Moderator
    May 2011
    907
    Fks are good mate (well i think they are) - i've got them, mine creaked for like 2 weeks even after a full 4 wheel allignment . then they settled in and they're fine now. the ride is firm but not unbearable and the handling is vastly improved over standard I got my custom tie arms from s3dave on here - can't fault them. or the fks.
    check it out!
    colicabcadam
    about 20% of AK's rear dampers make a knocking sound, i had mine changed under warrenty, i suggest you do the same - they will get worse and they WILL leak, they clearly had a bad batch made that's still out on the market
    Oct 2011
    Whitby
    27
    Quote Originally Posted by colicabcadam View Post
    Could well be onto something here like, sorry for being a complete donkey but what are the drop links??
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    Then never do them.
    Oct 2011
    Whitby
    27
    Quote Originally Posted by 16Klappe View Post
    ill check this out tomorrow, cheers for the help.
    colicabcadam
    open your boot, sit on it and bounce it up and down, you'll hear it, 99% it's the rear dampers, google fk dampers knocking, thing is returning them can be a long process - test my theory, as long as you have not lowered the car too much put the old damper back on and then bounce the back again.....
  1. Weitec Hicon GT Coilovers VS Bilstein B14 Coilovers
    By Greig300 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2011, 18:47
  2. HELP what coilovers to go for???
    By SneakaFreaka83 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th August 2010, 09:33
  3. Coilovers value?
    By chesney in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2008, 11:49
  4. COILOVERS
    By S3 SAF in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2008, 15:11
  5. Coilovers
    By Glenn A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th July 2007, 16:08
