JMB RetrofitsEM Tuning
Like Tree1Likes
  • 1 Post By S3 Paul
Thread: Help... Ive just noticed yet another vac hose that may be leaking how can i tell??
    S3 Paul's Avatar
    Oct 2006
    2,764
    While checking my DV i noticed that the pipe coming from the " vacuum reservoir " that sits above the 4th coil pack that goes to the n249 valve(or whatever silly number it has) goes from a rubber pipe to a plastic one for a bend... where the bend is looks over cinked and where it goes into the rubber just before the valve doesnt look sealed.
    If this was a boost hose ( one of the big ones ) using soapy water in a spray would show this ... But arent these vacuum hoses arent they? How can i check if its leaking???
    Noggy Blue 2001 S3
    Inertiauk's Avatar
    Mar 2011
    529
    Remove the pipe, cover one end , force air into the other ?
    But why not just do the N249 Delete to get rid of it all anyway ?
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    ^^^ +1
    <tuffty/>
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    738
    As above ditch the N249 and a load of potential vac leaks into the bargain
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    S3 Paul's Avatar
    Oct 2006
    2,764
    This is now the plan. I checked the pipe and not leak... but its a matter of time before one goes... So buying the silicone to remove it tomorrow.
    Inertiauk likes this.
    Noggy Blue 2001 S3
  1. hose leaking....part no. please
    By a3Nate in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2011, 18:46
  2. Leaking coolant Hose From Oil Filter on S4....
    By s4best4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2011, 22:24
  3. N249 4mm vac hose clips?
    By S3Lol in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2011, 22:39
  4. Vac hose clamps
    By bengal in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th November 2010, 13:46
  5. part number dv vac hose?
    By Bellic in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2007, 16:53
