Chris NottSky Insurance
Results 1 to 9 of 9
    Sep 2010
    498
    PD130 alternator belt change - How??
    I am in the middle of doing a few jobs on my car. One of them is replacing the alternator belt. I assumed that there would be a nut on the tensioner to slacken the belt. However mine doesn't have one and I can't tell how to get the belt off. Has anyone else done this job before?
    This is the tensioner that I have on mine:
    Belt Tensioner for the VW Golf / Bora 1.9 TDI ASZ engine | eBay
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    I took the whole tensioner off, only to find that it can be pushed/pulled one way to slacked the belt. It was quite stiff but once "bent" I re-attached it to do put the belt on.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    You see on the top of the tensioner, there's a square. Get a 16mm open ended spanner on that and you can move it to release the tension
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    Sep 2010
    498
    AHHHHHHH ok, I think I understand. I'll go have a look!
    Ashley g's Avatar
    Feb 2011
    High Wycombe Bucks
    178
    And there will be a hole that you can stick a pin in to keep it detentioned while you fit the belt
    2003-03 8L S3 Dolphin grey - Porsche 996 calipers - Mo-vit 325mm 2 piece front discs - 15mm spacers all round - Miltek resonated cat back - Genuine RS4's - Vredestein Sessanta's - Forge 007p - Forge TIP - JR cone filter - Poweflex diesel dog bone bush - AMD Remap - Blue Haldex controller - FK AK Coilovers - Seat Leon Cupra R top mounts - 8P S3 gear knob and gaitor - TT pedals - Neuspeed quick shift - LED number plate bulbs
    14.2 quarter @ 97 mph
    Power? 241 bhp with a boost leak, now fixed
    Sep 2010
    498
    Oh really? That makes sense actually. Thanks for the help guys! Much appreciated.
    Sep 2010
    498
    I think the time has come to replace the Aux belt tensioner. Has anyone done one on here? Is it a straight forward job?
    Lewis583's Avatar
    Mar 2010
    835
    If it is anything like the 1.8t tensioner it will be held on by 3 13mm bolts.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Sep 2010
    498
    From the look of it thats certainly what it looks like. Sounds pretty easy then. Literally just a matter of loosening the tension and undoing the bolts then.
  1. Audi A4 tdi PD130 Alternator Removal
    By samsam in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th April 2013, 22:25
  2. Alternator Belt
    By ScottD3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th December 2010, 11:47
  3. S4 alternator belt
    By TURBOTRONICS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th July 2010, 22:06
  4. Alternator Belt
    By tim-igoe in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2010, 20:03
  5. Change alternator belt at same time as cam belt???
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th August 2009, 11:38
