Chris NottSky Insurance
Results 1 to 11 of 11
    S3MVR's Avatar
    Oct 2011
    48
    Door blade removal tips
    Hi all,
    I've got a replacement passenger door blade for my s3 but i can't find any info on removal or refiiting.
    Anyone got any tips or know of any links to some info.
    Cheers!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,434
    4 screws mate, one at the front and one at the back of the door. There's 2 more under 2 rubber grommets under the door card, make sure you have a magnetic screwdriver, cos if you drop them, it's door card off time! Once you remoce the screw, the door blade just slides backward by an ince or so and pulls off!
    I highly recommend you get some new screw from Audi, they are 26p each(they was 6 years ago!) I think?
    Jun 2009
    Woking, Surrey
    131
    Out of interest Jojo, why do you suggest new screws? I'm planning on having my trims off soon so I can repaint them (meant to do it already. Typically)
    2001 (Y) Audi S3 AMK | Forge 007p | H&R ARBs | Powerflex Bushes All Round | Badger5 3" TIP & Jetex JR Filter | R-Tech Stage 1 Map | Brembo 4-Pot Callipers (Monoblock from Clio 197) with Ferodo DS2500 & EBC Ultimax Discs | N249 Bypass | Milltek Cat Back Non-Res Special Tips
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,434
    Quote Originally Posted by Hadders View Post
    Because they are tiny, and you will probably ruin the old ones whilst taking them off, the new ones are only pennies and look galvanised compared to the original ones I had.
    feck_on_a_stick's Avatar
    Dec 2011
    Belfast
    82
    Bringing this one back to the top. I'm trying to get the passenger side rear door blade off and can only find tips for the one on the door.
    From what I can gather it's just a matter of:
    - open passenger door
    - slide rear door blade left towards the open.
    I've tried this and it's not playing ball so before I go all out and but a bit of force into it, I just wanted to double check that this is correct. Obviously I don't want to break anything that's supposed to remain on the car lol
    Any pics of what's left on the car once it's removed would be great.
    2002 Nogaro blue Audi S3 (BAM)
    My intro thread
    http://www.audi-sport.net/vb/a3-s3-f...-s3-owner.html
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,195
    Here are instructions for the door blades:
    Attempting door blade removal later today
    If you mean the ones on the rear quarter panels then I think this is a matter of removing the internal trim and un-screwing them from the inside. Anyone confirm?
    Dec 2011
    Belfast
    82
    Thanks for the link and read it before but from what I can see its only for the blade on the door itself. Im trying to remove the one on the quarter panel
    My intro thread
    G60DAN's Avatar
    Cornwall
    321
    Open door and pull it towards the front and it just comes off well mine did.
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Yep it just slides out....put a cloth over the end and gently tap the blade with a rubber mallet and it will soon loosen off.
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,195
    So the blades on the rear quarter panels just attach to pins (ie no screws)? Presumably therefore re-fitting is just the reverse of removal, right?
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    No pins...a runner is built into the car and it just slides completely off the entire way. The door needs to be fully open.
  1. Door Blade for £20 worth it?
    By Gavin G in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd July 2011, 16:43
  2. S4 door blade colour poll.
    By quattrojames in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st January 2010, 10:58
  3. Wiper blade fitting tips.
    By plumet in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th May 2009, 14:30
  4. Door Blade fitting?
    By AudiSport in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th July 2008, 22:09
