AH FabricationsBadger5
Results 1 to 30 of 30
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    What's a high EGT temp?
    I've started taking a bit more notice of EGT temps (I usually just leave the liquid gauge on oil temp till its hot) recently and managed to get 920c yesterday on a very humid day here (we're getting closer to summer) up a steep hill with high load. I usually give the car a lot of mechanical sympathy as I know it can do wonders but just curious what a high temp is. I noticed the alarm on the liquid gauge is set to 950c.
    I am going to get an AH Fabs V2 cooler shortly (friend is bringing it over from the UK I hope) which I am sure will help cooling but not sure it has much effect on EGTs, more IATs?
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,503
    If you manage to hit 950 i think that's the fuel dump level for the ECU, the additional fuel cools the piston crowns and the exhaust stream, but limits power.
    Airflow is important in maintaining a decent temp on EGTs, so improving the AIT with the AH IC could help.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Depends on where you are measuring it from... in the k04 the probe sits in the hotside just below the flange and egt protection kicks in at 925 degrees... an S4 for example has the probe fitted in just above where the turbo is fitted and egt protection comes in at a higher figure.. 960 ish iirc...
    On an S3 then egt 's of anything much higher than 925 is potentially too high.... ideally you would want to keep them below 900 so that egt protection doesn't kick in killing performance and reduces the potential for cracking the housing....
    I seem to recall reading Garrett suggesting 850 across the turbine as a ball park...
    My probe is in the downpipe and see just over 700 max which is just over 800 across the turbine so for me if I saw 800 degrees or more on my gauge I would be worried...
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,131
    920's it starts protection fueling kicks in..
    what does your afr do under boost on liqui?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    I checked it before based on an image someone posted and it stayed in their sweet spot. I'll try and do some logging this weekend. It's only hit 920 once like I say, on that pretty steep uphill in 6th with decent throttle on a hot day. I guess it's always going to do that.
    RIP S3dave
    May 2004
    nr Glos
    7,131
    yep. its a k04 thing
    bill@badger5.co.uk
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    I must get round to checking mine now I have the decat and 3"downpipe. My old map killed my turbo and fuel pump due to the high EGTs. Quite an expensive bill to pay
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Cheers Bill.
    Westy: High EGT caused the fuel pump to fail because it dumps that extra fuel in which put it over the edge?
    Westy's Avatar
    Dec 2008
    17,264
    Quote Originally Posted by Sam_ View Post
    Cheers Bill.
    Yes mate. EGTs were constantly high so the fuel pump was working its nuts off to pump the extra fuel needed to cool the engine.
    S3 Build Thread
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    Quote Originally Posted by Westy View Post
    Was it running lean Westy ?? I'm currently having EGT issues , mainly the sensor maxing out but I also think my afr is not right.
    Im having my map taken off this afternoon to be on the safe side until I can sort out the lean issue.
    Cheers.
    S3 Big Turbo
    Westy's Avatar
    Dec 2008
    17,264
    Quote Originally Posted by sean_s3 View Post
    Cheers.
    Yeah hugely lean. The damage was already done by the time I went to see Bill and get my car on the rollers. I now run revo stage 2 software and I know that the fueling is spot on.
    S3 Build Thread
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    Not good at all then . What kind of Afr values were you seeing when running a lean mixture ?
    S3 Big Turbo
    Westy's Avatar
    Dec 2008
    17,264
    Have a read through my progress thread mate, all the rolling road graphs are in there with the shocking fueling.
    S3 Build Thread
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    Ok will do.
    Cheers .
    S3 Big Turbo
    Westy's Avatar
    Dec 2008
    17,264
    Here you go Sean:
    S3 Build Thread
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    Thanks for this.
    Lambda of 11 at redline , Is that correct ?
    S3 Big Turbo
    Westy's Avatar
    Dec 2008
    17,264
    The lower the AFR number the richer the fuelling. Ideally the fuelling should be around 12 but as you can see, my car was running lean.
    Where the graph dives down on each of the 4 runs is where the EGT protection is kicking in and dumping fuel into the engine to cool.
    S3 Build Thread
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    Thanks , Understanding the fueling ratio's can be a bit mind boggling !
    S3 Big Turbo
    Westy's Avatar
    Dec 2008
    17,264
    here's a graph with the bad map compared to the new Revo with decent fuelling. This was stage 1 before I went stage 2:
    S3 Build Thread
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    Fueling hold nicely at 12.5 . Im back on standard map now so I will have to do some logging of Afr and fuel trim to get to the bottom of my lean issues and high Egt. Hopefully it will be something simple to fix !
    Cheers.
    S3 Big Turbo
    RIP S3dave
    May 2004
    nr Glos
    7,131
    Thanks for this.
    Its not correct as far as fueling is concerned, but a result of the 14afr under boost causing very high egt's which when protection kicks in fuel dumps, and the 11's happen. During this the timing pull is also v.high compared to cars with correct fueling under boost.
    pikey map.. all the boost and no fuel adjustments.. see it often.. from some "named" tuners too *cough*
    bill@badger5.co.uk
    Westy's Avatar
    Dec 2008
    17,264
    pikey map..
    It was indeed. I learnt my lesson the hard and expensive way. Never again.
    S3 Build Thread
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Yes from some supposedly reputable tuners having maps requesting low fueling which could have possibly caused half my problems
    And when checked said that'll be alright with egt's peaking at 1020 degrees when they drove it with me logging???
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Westy's Avatar
    Dec 2008
    17,264
    Quote Originally Posted by StaceyS3 View Post
    Too many cowboys out there unfortunately. They want to map a car, take the money and run.
    S3 Build Thread
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    Thankfully we have vagcom to help us there to double check everything is up to scratch , even when coming away from tuners with what is supposed to be tried and tested maps.
    @ Westy how long did you have the dodgy map for ?
    Cheers.
    S3 Big Turbo
    Westy's Avatar
    Dec 2008
    17,264
    I had the bad map for almost 2 years. I then visited Bill and went on the rollers to find out how bad it was. When I sent my turbo away to be refurbed it turned out that it was beyond repair and has been subjected to some very very high temps:
    S3 Build Thread
  28. #27
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    That photo should be posted whenever a new remap discussion comes up . I bet there are plenty of people driving around with bad maps who do not know the damage it is causing.
    S3 Big Turbo
  29. #28
    Westy's Avatar
    Dec 2008
    17,264
    I have worse pics!
    S3 Build Thread
  30. #29
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    That first pic is scary !!
    S3 Big Turbo
  31. #30
    RIP S3dave
    May 2004
    nr Glos
    7,131
    really? 1020'c measured where?
    bill@badger5.co.uk
  1. VCDS Temp reading high?
    By S3Lol in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2011, 11:17
  2. S4 Oil Temp high
    By EnzoS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd December 2009, 11:07
  3. high oil temp
    By EnzoS4 in forum VCDS (formerly VAG-COM) forum
    Last Post: 11th August 2008, 00:07
  4. Oil temp at high speeds?
    By Toxik-Signal in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2007, 09:07
  5. high water temp?
    By dultanur in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2006, 13:39
