Volks AutosEM Tuning
    Oct 2011
    13
    wierd alarm problem
    right please help im going mad
    lock the car alarm works and arms
    unlock the door the doors unlock and the alarm stays active open the door alarm goes off
    the only way to get into the car and unlock all doors and diable the alarm is to use the boot lock !!
    PLEASE PLEASE PLEASE SUMONE HELP ME
    Jun 2003
    World of my own
    9,813
    If the alarm is doing wierd things then chances are it's the age old back up battery issue. Over time they leak and corrode the PCB. This usually manifests itself with 3-4 beeps when you first get in the car and then the alarm going off at 3am for no reason, but because the acid can eat into the circuit board then all manner of issues can arise. Just disconnect the thing as it's a totally pointless alarm anyway. Or follow the DIY fix on here, loads of posts about it.
    Alex Turner
    Oct 2011
    13
    thanks for the reply andymac the alarm doesnt bleep 3 times just doesnt disarm when you turn the key in the door but does from the boot
    gonna get a key fob blip and see if that helps matters
  1. alarm problem
    By freddie 5 in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th March 2011, 20:56
  2. new wierd problem
    By maxlbrown in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th May 2007, 13:42
  3. wierd indicator problem
    Last Post: 7th August 2006, 15:06
  4. Wierd timed / auto lights problem
    By imported_CurryMilkShake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd March 2005, 19:47
  5. ALARM PROBLEM
    By JohnBoy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th July 2004, 19:41
