Chris NottMonster Motorsport
Page 1 of 2 12 LastLast
Results 1 to 40 of 64
Like Tree1Likes
Thread: S3 8L Haldex Issues - Driving like a solid rear diff!
    Jan 2009
    37
    Hi Guys looking for some advice.
    Basically bought an 2003 S3 8L, first thing I noticed was it was able to spin the front wheels, leading me to believe theres a haldex issue.
    Checked No31 fuse - Perfect
    Checked Earth Strap on diff - Broken - Now fixed
    Check wiring - the small stuff cable that goes in 90 degree bends I believe plugs into the haldex pump was disconnected - I connected
    Now the car drives like it has a fully locked rear LSD, no more wheel spinning but it scrabbles stones etc when doing 3 point turns, or on full lock driving slowly. Obviously the rear diff shouldnt do this.
    Got the car VAGCOM read and showed an intermitent fault with Haldex but not the controller.
    Where do I go from here? I have ordered new haldex oil and filter in the hope that its dirty oil causing the clutch plates to bind?
    Any help much appreciated.
    Jan 2009
    37
    Ok small update, went to a carpark and drove in circles, sure as the rear end is scrabbling for grip, however tried the handbrake test and pulled it up one nick, haldex disengaged!
    Is this pointing towards the control unit?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    This sounds like the haldex clutch pack has seized.... a few others have had this experience too... this is typically because the oil and filter for the haldex isn't changed regularly and the plates stick together...
    Haldex fualt code
    Haldex problem
    A search will have picked these threads up...
    Maybe an oil and filter change might help.... either that or replacement haldex unit...
    <tuffty/>
    Jan 2009
    37
    Can anyone tell me would an 01 VW Golf 4motion's Haldex Controller be the same as my S3 8l?
    Jan 2009
    37
    Haldex fualt code
    Haldex problem
    <tuffty/>
    See I initially thought this too, but if the clutch has seized how come when I pull the handbrake it is able to disengage it automatically?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Quote Originally Posted by Jas Lad View Post
    Under normal conditions the haldex isn't engaged anyway... the car is essentially front wheel drive... the sticking haldex plates could be causing drag on the rear diff... beyond that I have no answer but the car low speed manovoures are not sufficient to engage the haldex so I suspect its the plates sticking and not the controller... if the controller wasn't working then you would not have rear drive...
    <tuffty/>
    Jan 2009
    37
    So you think give the oil a change first and after that try a new haldex unit?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Oil change won't hurt... I doubt it will be an instant fix and you may have to change the oil again in a 1000 miles or so if its that bad as it will get contaminated with the cruddy stuff thats been left behind...
    <tuffty/>
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    Mine wont engage at all and it's the intermittent mechanical fault code I get too so hopefully an oil and filter change fixes it. If not new haldex unit time. Why didn't they just make it proper Quattro like the a4 etc? So much more relliable.
    Chugger
    North Devon
    2,716
    I think haldex is pretty reliable if properly maintained, eg. Oil and filter change every 20k
    57 A3 2.0 TDI Sportback (140)
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    Does changing the haldex oil also change the rear diff oil or are they separate?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,836
    Quote Originally Posted by Alex C View Post
    Seperate.
    You've got to have a laugh!
    May 2008
    perth
    1,197
    With the ammount of threads on here and other forums about haldex problems i wouldnt say its that reliable. They just over complicated things by using the haldex system if you ask me,whats wrong with a proper diff?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Quote Originally Posted by ian52 View Post
    Haldex isn't a diff... its a clutch... there are benefits to using the haldex system rather than a full time torsion setup like 'proper' quattros (lol)
    Haldex is a generally reliable piece of kit but needs regular servicing like anything else... on older cars that are now getting serviced by regular garages its easy to overlook a haldex service and this can overtime have a detrimental effect on its reliability...
    My S3 has 114k on the clock but I have religiously serviced both the engine and haldex appropriately and is is still good in the world...
    If you are capable its worth doing these services yourself as they are not difficult to do and the benefits are obvious... I drop my engine oil every 5/6k now and do the haldex oil every 10k or so....
    A lot cheaper than replacing the haldex unit for sure...
    ...and lets not forget that the Veyron uses Haldex clutches so if its good enough for a car costing over a squillion pounds then its good enough for my lowly S3...
    <tuffty/>
    vrbob's Avatar
    Jun 2007
    Southampton
    2,279
    Just did the haldex oil and filter change on my car. Bought the oil, filter and filter tool off ebay for about £50 took me about 40mins to do the actual change. The oil i took out was pretty dirty and had a few bits in it so am glad its been done as i think iots been a while and for the effort it took to do i cant see why its neglected.
    Hopefully this should keep my 4wd going well ready for the winter
    Mods : Revo Stg 2 & Select+, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Jan 2009
    37
    Its a terribly flawed system imo and tbh once I sell the car probably my last, never had any such problems on any M car subaru/evo...
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,172
    But you did buy the car knowing that there was a problem with the 4WD system...? I'm sure that not maintaining any car component correctly will cause it to fail.
    Fox R likes this.
    May 2008
    perth
    1,197
    I only found out after buying mine it didn't work. Got the oil and filter sat here. Just need the tool to get the filter out now.
    Chugger
    North Devon
    2,716
    but they both used 50% more fuel
    Aug 2011
    134
    If you need a replacement i have a perfect S3 diff/haldex set-up you can have for £150
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Quote Originally Posted by s3matty View Post
    Would prefer it if you PM'd them my friend
    <tuffty/>
    www.badger5.co.uk
    May 2004
    nr Glos
    6,937
    The Haldex oil/filter servicing gets forgotten most of the time...
    When I ask haldex owners the question re when was it last changed most dont know its even required!
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Mar 2011
    The friend of my cured the same problem by fixing both longitutional & lateral sensors.
    I sold my car inspected by VW saying it is in good shape, but it was doing that strange jerking
    I am here: http://maps.google.com/maps?ll=56.916761,24.116075
    Chugger
    North Devon
    2,716
    Well when I took mine to the dealer for its last service, I had to suggest they did the haldex oil and filter. They wouldn't of bothered otherwise, even though it was in it's schedule. Maybe in an effort to be competitive, they just do the minimum
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,172
    It's crazy. Just get them to change the oil/filter once a year, stamp the service book and leave. Then do the rest of the jobs yourself so you know they're done properly. It's not even as if the Haldex & filter is hard to do!
    Jan 2009
    37
    Quote Originally Posted by sportstractor View Post
    My PPP blobeye was quite good on fuel, and M3's I have had all done around the 30 mark which wasnt bad.
  28. #27
    Jan 2009
    37
    Thanks mate i'll see how I get on with my oil change then drop you a line...
  29. #28
    Jan 2009
    37
    Can anyone tell me what haldex's/rear diffs i can use in a 02 S3?
    Was told cars without ECP can't be used on mine as it has traction control etc? So there for would that rule out pre facelift S3's?
    Or is it only the controller that causes the issue?
  30. #29
    Jan 2009
    37
    Just bought a 2002 41k S3 diff... hope it works!
  31. #30
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    712
    I've always wondered does anyone actually believe advertisers when they state a a particular part has come off an XXX milegae car ? Unless you see the car with your own eyes and check the mileage when they take it off then surely the part will always be off a so-called low milegae car !
    someone else had similar problem on the boards and replaced the whole unit and cured the problem........and others I've read...NOT.
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
  32. #31
    Jan 2009
    37
    New diff is in it, its ****ed too... making like an ABS pulsing vibration when doing 3 points etc.
    Think its the controller so going to swop it for me old one, if that doesnt work guess its another diff and more money fitting/oils.
  33. #32
    Nov 2008
    154
    My haldex would occasionally lock, usually i'd notice when i'd park and it would go BANG after turning the ignition off and clunk the drivetrain from the back as the trasmission unwound. Only did it when the ignition was off so similar to yours, locked when powered but would happily unlock eventually. Don't forget when driving it's not 'open', it delivers 5% power the rear (or similar) probably to prevent drivetrain shunt by keeping the rear diff gears engaged in the forward direction.
    Mine was solved with new oil / filter. I don't think it had been changed in 60k. I change it around every 10k and it stays quite sweet. It's not a hard job.
  34. #33
    Jan 2009
    37
    Guys its had a new diff and iv swopped the haldex controller from my "new" diff to me old one and its got worse again, all very similar problems, no faults showing on vagcom except this which comes and goes:
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 01: Engine
    Controller: 8N0 906 018 BH
    Component: 1.8L R4/5VT 0001
    Coding: 10710
    Shop #: WSC 66565
    WAUZZZ8LX21016331 AUZ7Z0A1987800
    No fault code found.
    Readiness: 0010 0001
    Address 03: ABS Brakes
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    1 Fault Found:
    01324 - Control Module for All Wheel Drive (J492)
    49-10 - No Communications - Intermittent
    Anyone any ideas??
  35. #34
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Exactly what it says on the tin really... check the earth strap, the plug wiring etc... failing that its the controller...
    <tuffty/>
  36. #35
    Jan 2009
    37
    Brand new earth strap fitted
    Diff
    Diff oil
    Haldex filter
    Haldex Controller/Unit (probably faulty controller)
    Haldex Oil
    A friend has a scrap v6 4motion and has very kindly allowed me to try his controller so going to give it a bash....
  37. #36
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,512
    I put an older controller in my car as the differences between the designs of the two were visible! When you drive, is the ESP light constantly on? Have you jacked the car on all 4's to see what it's actually doing?
  38. #37
    thegoal007's Avatar
    Apr 2008
    surrey
    712
    as I mentioned earlier....and some having replaced the controller and haldex still NOT fixed the problem. I have haerd of one person replacing the abs control unit and fixing the problem.
    And...just in case you thought what else could could it be....well, as someone else has mentioned you also have the 2 sensors in the car and also the 4 at each wheel - ALL of which contribute to the working of the haldex unit !
    I believe the haldex IS WORKING properly, it's just that something is telling it to engage at the wrong time.
  39. #38
    Jan 2009
    37
    Quote Originally Posted by Gops View Post
    No ESP light, traction control can be turned on/off
    All 4 wheels are def working, the problem is the rear is locked solid!
  40. #39
    Jan 2009
    37
    Quote Originally Posted by thegoal007 View Post
    Totally understand mate, but i checked with a snapon and vagcom ecu reader, all speed sensors are reading the exact same, steering angle etc also spot on, brake light and handbrake switchs work 110% too, no errors and on my tests show being engaged/disengaged.
    ABS unit is a good shout. Big job replacing?
  41. #40
    Jan 2009
    37
    Okay another update.
    Vagcom testing, section 22 AWD
    Basically If I run the diag. test, to engage the pump I can hear it turn off and on as the test runs, good I think
    Next clutch engage/disengage no problems
    Now while testing, with the pump state in "hi" all I get is clunk clunk clunk, when disengaged and pump goes into "lo" state, the car does 3 point turns etc perfectly, no issues.
    If I do a hard launch or hard circle it pushs the pump state into "hi" again producing the clunking and is thus stuck in "hi" untill I go into vagcom and tell it to cycle again.
    So this is leading me to one of 2 things, the controller isnt capable of telling the pump the correct state to be in (I have just got a 110% working controller yet to fit) or the pump is getting stuck in "hi" although VAGCOM is able to tell it to go to "lo"
    My money is on the controller? Although no errors are showing.
  1. rear diff (haldex)
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2010, 15:50
  2. Rear diff / haldex
    By jonny87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2010, 12:29
  3. Rear Diff n Haldex
    By Lemon S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2010, 11:14
  4. Rear diff oil? (not haldex)
    By S3-Oski in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2009, 08:32
  5. S3 8L rear diff and haldex swap
    By j555pre in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2009, 14:46
