AH FabricationsChris Nott
Page 2 of 2 FirstFirst 12
Results 41 to 64 of 64
Like Tree1Likes
Thread: S3 8L Haldex Issues - Driving like a solid rear diff!
  1. #41
    larsmate's Avatar
    Apr 2004
    114
    Thought you'd already swapped controllers. So you think the second controller was also a dud and now you're on your third?
    Black S3 | MY09 | APR 3.4 Stage 2+ | RNS-E LED | Tints | 19" OEM RS3 Rotors | APR DP | APR HPFP | WALK | Bilstein B14 Coilovers | Lamin-X | Ashtray delete | P3 Gauges integrated boost gauge | BlueVAG VAG-Check |
  3. #42
    Jan 2009
    37
    My original diff was taken out inc its controller, swopped with 2nd hand diff and its controller, it was no better so i swopped it back to my original controller which made it worse, so with the change in behaviour im thinking its 2 duff controllers, I have a 110% working controller from an 01 4motion Golf to put in.
  4. #43
    larsmate's Avatar
    Apr 2004
    114
    Best of luck!
    My car was two wheel drive for around six months until I replaced the pre-charge pump. This fixed the problem however now I get some slight locking of the inside rear wheel when driving very slow and on full steering lock. Probably not the same problem as yours but leads me to wonder two things - as someone mentioned earlier - the diff and the haldex are seperate but do they share the same oil? I have no controller problem but get similar symptoms to you except it only happens when the car is cold.
  5. #44
    Jan 2009
    37
    Answer me this, did you loose much haldex oil when removing the precharge pump or would I need another tube?
  6. #45
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    729
    not sure on the answer above, but bear in mind the majority of people who end up either replacing the diff or controller have never seen any errors show up on vagcom.....if only it was that straight-forward.
    Also bear in mind there are so many cars with this problem (well, i think so - a lot don't even want to mention it and rather just sell them on) it's best to get one off an Audi TT with frontal damage. Strangely I've not heard many TT owners complain about this rear locking issue.
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
  7. #46
    larsmate's Avatar
    Apr 2004
    114
    Mechanic did the job but I did get charged for oil. I had no errors in vagcom saying the pump was dead but your pump is ok otherwise yourwheels wouldn't be locking up.
  8. #47
    Jan 2009
    37
    Ok another update.
    Got the controller off the mk4 4motion fitted tonite.... drives exactly the same as my last controller did. So i'm ruleing out the controller being the problem.
    All im left with now is to swop pumps from my old diff to this one and see if the behaviour changes. After that im out of ideas
  9. #48
    larsmate's Avatar
    Apr 2004
    114
    Thumbs down
    So you've narrowed it down to being a mechanical fault (barring sensors). I don't believe there's any servicable parts in Haldex or diff so you'd better keep an eye out for a front ended TT.
  10. #49
    Jan 2009
    37
    Well im going to swap over my haldex pre charge pump to see if this fixes it or changes its behaviour, if it does i'll get the one off the 4motion.
    After that im calling it a day and selling it. I've spent hundreds.
  11. #50
    Jan 2009
    37
    Just a thought but would it be my steering angle sensor? Perhaps the car doesnt know what the steering angle is and thus doesnt know when to turn the pump off?
    Where is the sensor located at? VAGCOM shows the angle quite clearly correct so maybe not?
  12. #51
    Jan 2009
    37
    Has anyone a name or number of a haldex specialist I could get a chat with?
  13. #52
    Jan 2009
    37
    No one able to help? Looking like Audi is my last resort.
  14. #53
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    I use AmD in Thurrock and they know what they are talking about. Ben is helpful there. There may be an AmD closer to you.
    Plenty of others of course.
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
  15. #54
    Jan 2009
    37
    Thanks i'll give them a call, problem is im in Northern Ireland!
  16. #55
    thegoal007's Avatar
    Apr 2008
    surrey
    729
    I have to say, one fairly unique difference with your problem is that when you try the handbrake trick of lifting it up one notch then you never have a problem- 99% all rear locking wheel issues I have read stated that the handbrake trick did not work for them.
    Surely that must mean something to an expert and it's a fundamental point on where the problem is.
  17. #56
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Quote Originally Posted by thegoal007 View Post
    To me that means electrical, not mechanical. Means the handbrake switch works and haldex controller works, otherwise itd do nothing.
    Steering angle sensor usually brings the esp light on.
    What happens when you have the car jaxked up and you spin 1 wheel?
  18. #57
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,522
    Lifting the handbrake one notch tell the haldex unit not to activate the electronic controller. So i'd assume electrical too as the Haldex is engaged when it shouldn't be
  19. #58
    Jan 2009
    37
    Without no thanks from any Audi specialists or mechanics I fixed it myself, swapped the precharge pump and done an oil change... et voila, working 4wd PERFECT, so happy!
  20. #59
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    good news mate! Got there in the end.
  21. #60
    Jan 2009
    37
    I know im so glad its sorted, original diff must have had a seized clutch plate, 2nd diff had a faulty precharge pump... so now iv a spare working controller to sell which should recoup some costs I guess..
  22. #61
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    in vagcom could you run a test on the pump tho? and hear it prime itself etc etc
  23. #62
    Jan 2009
    37
    Yep it all sounded normal enough but on the diagnostics you could see the pump on a low load basis wasnt dropping from a hi state into the low which it should have..
  24. #63
    thegoal007's Avatar
    Apr 2008
    surrey
    729
    which year, engine model is your car ?
    your fix is a first I've heard (pre charge pump failure) for this kind of issue.
    especially wierd when you couple the specific problems you were experiencing - so it doesn't quite make sense that was the issue.
  25. #64
    Jan 2009
    37
    Its a 2002 BAM... and the replacement diff apparently came out of one the same model.
  1. rear diff (haldex)
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2010, 15:50
  2. Rear diff / haldex
    By jonny87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2010, 12:29
  3. Rear Diff n Haldex
    By Lemon S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2010, 11:14
  4. Rear diff oil? (not haldex)
    By S3-Oski in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2009, 08:32
  5. S3 8L rear diff and haldex swap
    By j555pre in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2009, 14:46
