EM TuningVolks Autos
Results 1 to 22 of 22
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Unhappy New S3 owner but very unhappy
    Hi peeps,
    Last week I became a very happy man, I've alway wanted a S3 for as long as I can remember & now I have one.
    Its in really nice condtion with full service etc but one thing that did play on my mind was that the person I got it off only had it a few months....
    Anyway, after getting it home & down my mates garage on a ramp I find out that the 4x4 isn't working!
    We put it on VAGCOM but couldn't comm with the haldex, which reading about it on this forum could be a problem with the muti plug.
    But now that isn't really a big problem as 2 of the big end shells has spun has damaged the crank & 2 of the rods.
    which leads me to a question for you guys, which engine codes can I use as a replacement?
    My engine code is APY, could I fit a AGU engine with all the bits off of mine?
    Many thanks
    Pat
    Sep 2010
    498
    Not to state the obvious but did you check the fuse? Sorry to hear about your problems
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Hi, thanks for the reply.
    Is that fuse 31? If so yes I did check that.
    I am here: http://maps.google.com/maps?ll=50.711196,-3.507963
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Check the earth strap too... there is a braided strap connected from the body to the rear subframe... can't remember exactly where it is but you will be able to see it looking underneath the car
    <tuffty/>
    Sep 2010
    498
    Not sure which fuse number, should say in the book or on the back of the trim cover. Like said, check earth strap too. Also, has it been vag com scanned?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Quote Originally Posted by doublem_1 View Post
    Read the posts above mate, he has checked the fuse and used vagcom lol ;P
    <tuffty/>
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    You could fit an agu engine in place of yours. The agu lump has a different compression ratio but it does work fine. You could fit your pistons with new rings in a good agu block and it would be spot on, complete with a built in large port head conversion!
    Audi S3 1.9 GT30....
    ....that is all
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,013
    Visit 16Klappe's Instagram Channel
    What miles is this thing on?
    I quite often say I'm going to do things.
    Then never do them.
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Thanks for the replys,
    It's coming up to 110k so still low mileage wise really, the person (kid) was a bit of a breaker as I've found out!
    Are you sure the comp is different with the AGU?
    Also what else would you say to do as the engine will be out
    Cheers, Pat
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    yes compression is slightly different, 9.5:1 compared to 9.0:1. this can be considered a good thing and possibly give some extra power when tuning (going off wellys car).
    if you can get an agu engine for a good price its well worth the swap imo, large port head, high CR, and still has 20mm wrist pins.
    have yoiu consider rebuilding yours with forged rods and new bearings etc? this would be a good basis for mods in the future if you do get carried away.
    stuff you should consider doing if it hasnt been done is, oil pump, cambelt tensioner, cambelt, water pump, head gasket.
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    We have thought about a rebuild, but the crank is shot, I put a new set of gen shells in & with in 8.7miles it picked up again on the crank. The AGU does sound a good way to go. Where is the best place for uprated parts? Rods etc?
    Many thanks
    Pat
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    so is the AGU block a different compression? I thought its was the piston that altered the compression or am i getting mixed up? haha.
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    5,013
    Quote Originally Posted by pats3poa View Post
    Many thanks
    Pat
    Get yourself on JBS, hmmmmmmm yummy!!!
    IE Rods are what I want.
    Then never do them.
    Inertiauk's Avatar
    Mar 2011
    529
    I got my IE rods from backdraft motorsport, but badger5 does them as well.
    I got my big end bearings off ebay.
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    an agu can be picked up on ebay relatively cheap, and any parts not used can be sold to recoup some cash.
    bill @ badger 5 sells IE rods. backdraft motorsport also. a quick internet search will bring up a few. just be careful of import duty etc.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    yeh dani its the pistons that alter it. most 150 and 180 1.8t engines are 9.5:1 CR. see here.....1.8T Info Sheet
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    Thought so, so you could run AGU pistons with uprated rods in our s3 blocks?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    yeh you could, making the CR 9.5:1.
    just gotta find a set, or someone willing to break their engine apart.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    Looking at that sheet, its says APY/BAM/AGU are all 9.5.1 CR!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    good spot! theres some conflicting info there, one sheet says 9.0:1.
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Wow, cheers for all the info!
    I'm not in any rush, as I want to get it right first time, & now the engine has to come out I mite as well do the hardest jobs now.
    I'll do some searching over the weekend for rods etc.
    I'll keep you all up to date on what I'm doing, but anymore info/links would be great!
    Again thanks
    Pat
  1. Possible New A3 Owner
    By Little Big Man in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2010, 21:56
  2. Unhappy S3 Bluefin Owners.
    By Spin140 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd September 2008, 20:28
  3. Hi, new A3 owner...
    By Niko in forum The Welcome Section
    Last Post: 7th October 2007, 16:11
  4. New A4 Owner!!!
    By vinesh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th September 2007, 23:13
  5. Long TIme AUdi Owner, New A3 owner - Hi From Sunny Arizona
    By acewaterson in forum The Welcome Section
    Last Post: 29th June 2005, 13:27
