Chris NottSky Insurance
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By superkarl
Thread: poxy squeak what the..
    Oct 2010
    41
    help! has anyone had a loud squeak on there S3 I think its on the front it is loud and only stops if I go on a smooth straight road if I park or go into the garage its off squeak squeak its doing my head in some said it may be the suspension front legs what ever that is ,Ihave pushed the car down on each corner, it squeaks on all corners, any ideas would be welcome, and before you all tell me to turn up the radio, done it and I can still hear the f...ing thing, it does my head in
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    jack it, silicone lube all the antiroll bar bushes, other bushes, drop links, shock mounts
    could be shocks n springs.
    could be top mounts.
    theres just so many things it could be.
    MattW86 likes this.
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    I have a similar squeak which comes and goes, i believe it is to do with the anti roll bars. There is supposedly a plastic 'shim' which after a while wears down and you get the squeak. look at getting some new anti roll bars or put some grease on them.
    I could be wrong, one of the more knowledgeable guys will give you a definite answer
    Good luck
    Matt
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    no shims on the anti roll bars.
    the amount of stress they are under when loaded its common for them to squeak (i've got to lube my girlfriends up this weekend, waheeyyyy)
    its not difficult to under the ARB mounts and squirt a little copper grease in there.
    if you have squeaks id just go mad with some spray silicone lube under the car lol
    May 2011
    Sunny South wales
    82
    Loose wheel bolts, Bottom ball joint/s dry ? but you would normally hear them squeaking or creaking when you turn the steering wheel. or you could try spraying each bush or joint with some lube to see if the noise lessens or goes away.
    Oct 2010
    41
    yes thats the right description it creaking, I will spray everything, is there a special spray as I dont want to replace every bush on the motor because all the rubbers have rotted with me using the wrong grease, cheers Antwan
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    The only thing that got rid of my creaks was changing the top mounts...with a load of white grease for good measure...
    Oct 2010
    41
    Thanks Dave, any idea of the cost of the tops mount, and how difficult to do? would be gratefull, PS the rear light I got from you last year fitted just as you said nice and easy, hope this top mounts replacement is as easy CHEERS LYNN
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,626
    Quote Originally Posted by speedy lynn View Post
    Halfords will sort you,spray every joint in view there is a link to doing ARBs somewhere,I'll find it.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Great,, top mounts SKF SEAT | Euro Car Parts UK’s No.1 Car Parts Retailer
    They will have 20 - 30 % off sometime in the month then,,, buy buy buy
    dificulty --- if on standard suspension, a bit of a stripdown, there will be guides on here, if on coilovers its very easy...
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    999
    Give this a go: Waks Wide Web
    Worked for me
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    Oct 2010
    41
    thanks to all the boys, i'll let you know sunday night how it goes or perhaps the poxy noise will still be there?????
    Oct 2010
    41
    thanks mate will try the easy option first if I still have the noise, I will then go and get the top mounts, cheers Dave
  1. Squeak Squeak Squeak ... arrggghhh
    By Inertiauk in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2011, 21:36
  2. Squeak
    By dc240969 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th July 2009, 11:16
  3. Poxy clutches!
    By pdv40 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2009, 10:42
  4. Poxy OSI Model
    By Caesium in forum General Chat
    Last Post: 16th March 2007, 16:28
  5. Poxy Speedcamera!!!
    By imported_Gibbsy in forum General Chat
    Last Post: 12th December 2004, 23:01
