AH FabricationsChris Nott
Results 1 to 7 of 7
    Jun 2011
    London
    Lambda sensor/oxygen Sensor
    I need help i have an audi a3 1.6. i have put an 2 1/4" cat back exhaust system on it my emissions are 9% i need to know if my car has one or two lambda sensors
    Gemma
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    What year is it?
    Homer Simpson
    Jun 2011
    London
    1998 mk 1
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I'm struggling to find out as it looks like they changed various things mid 1998, so depends what side you are. Phone up your local audi dealer and give them the reg number, they'll be able to tell you for sure.
    Alternatively, look under the car around about the drivers seat, if you can see a lambda, there is your answer...
    Homer Simpson
    Jun 2011
    London
    Also i need to change crankshaft sensor as ive jus done the camshaft n still coming up with hall sensor on ecu. where abouts is the crankshaft sensor placed??
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by GemmaLouise View Post
    Normally on the front of the block... I don't really know off hand o the 1.6 engine.
    Homer Simpson
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    A3 1.6 Engine cutting out when hot then difficut to start (ASR light on) SOLVED!!!
    In this thread the guy replaces the crankshaft sensor and it is where Welly states
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
  1. Pre Cat Oxygen Sensor - Where to Buy?
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2011, 09:45
  2. Intermittent Oxygen Sensor
    By guinness in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2011, 13:29
  3. 17522 Oxygen (Lambda) Sensor
    By RussUK in forum VCDS (formerly VAG-COM) forum
    Last Post: 9th August 2010, 16:25
  4. Lambda sensor
    By Fuzzy felt in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2010, 15:18
  5. oxygen sensor problem, help pls.
    By A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2009, 19:40
