AH FabricationsChris Nott
Results 1 to 10 of 10
    Sep 2011
    59
    Anyone with VAGCOM in Oxfordshire??
    Hi all,
    Just wondering if anyone has a diagnostics kit around oxford my emmisions light has come on, i am pretty sure it will be because of my decat but just need a check and don't want to pay a stupid garage price of £50+
    Today would be good if not can be a weekend.
    thanks
    :y:
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,486
    Take a look in the vcds section. There is a vcds users map within that section, so there may be a user near you. Good luck.
    Sep 2011
    59
    messaged the nearest but he hasn't been on in ages and he is a fair few miles from oxford. would of thought there would be at least 1 in oxford its pretty central lol.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,486
    You could buy cable from user NHN on here. Worthwhile investment.
    Sep 2011
    59
    Fault code cleared and it hasn't come back on since..but the fault code as follows:
    P0136 O2 Sensor circuit malfunction (bank1 sensor2) so this is the sensor after the cat, now
    sensor 1 reads 0.43V-0.4350V
    sensor 2 reads 0 V
    is that a fault with the sensor or is it because of the decat?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,520
    its cos you got a decat
    it will show again in a 100/200 miles
    1 get it wrote out of the ecu
    2 try a spacer sometimes they work
    3 live with the light get a vcds and reset when it comes on
    Sep 2011
    59
    Ok, will try a spacer.
    bez101's Avatar
    Jul 2008
    8,520
    when you fit it if the lights on you will need to reset
    Universal O2 Sim Oxygen Sensor Simulator Spacer OBD2 02 18mm OBDII | eBay
    only 1 i can find
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    I'm oxford too, was in need of vcds a while back, no one around here has it!
    It is something I'll be getting after the Xmas period though for sure
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Sep 2011
    59
    Quote Originally Posted by S3featesV9 View Post
    well the chap who did mine was in grove, so not far from oxford maybe 10 miles or so.
  1. Good Bodyshops In Oxfordshire / Surrounding Areas
    By Lance-22 in forum General Automotive Chat
    Last Post: 30th August 2011, 23:03
  2. Help required - Oxfordshire UK
    By RodA in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th August 2011, 17:43
  3. Hello from Oxfordshire
    By MFC9 in forum The Welcome Section
    Last Post: 28th June 2011, 19:44
  4. Oxfordshire car meet
    By joshhatton in forum Smaller (Local) Events
    Last Post: 7th May 2009, 13:57
  5. Valeting service recommendations in Oxfordshire?
    By JCC1981 in forum Detailing
    Last Post: 19th September 2006, 10:30
