AH FabricationsJMB Retrofits
    Mar 2011
    11
    Coilover problems, help needed asap!
    hey guys,
    was fitting coiolvers on the mates car (a3 8l 1.9 tdi) and it was all fine & dandy on passneger side, but the strut would not for the life of me move on the drivers side, its not siezed cause the hub will move up and down until a certain point and no amount of wd40 or hammering could get it out.
    its almost like something else is restricting the hub from coming down far enough to let the strut out, does the subframe need to be removed or anything, and is it a really hard job on axle stands? Thanks, any help appreciated!
    s3schofield's Avatar
    Sep 2009
    Burnley Lancs
    129
    Compress the spring or remove the calliper bottom ball joint and driveshaft to get hub lower
    Audi S3 8L 2001 imola yellow autobahn tip, heatshield, metal mesh cone filter, apr r1 DV, REVO stage1, SPS box, Weitec coilovers, forge short shift kit, bosch aero wipers, 20mm rear spacers Wanted 3"Dp Decat rear arms pm me
    my progress thread http://www.audi-sport.net/vb/a3-s3-f...ss-thread.html
    BENJAMIN's Avatar
    Mar 2011
    472
    Compress the spring with clamps and hit the strut upwards.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,368
    it's the driveshaft mate! Classic problem.
    the pax side shaft is small, there there's enough play for it to drop down far enough to let the strut seperate from the hub.
    On the drivers side, the shaft is longer and thicker, and as you try and bash the hub down, the driveshaft sits on the subframe and it will go no more!
    Undo the lower ball joint, and move the hub forwards, then try again and it'll work easily
    Simples. but it catches a lot of people out!
  1. help needed asap!!!
    By leeds A3 1.8T in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2011, 15:19
  2. urgent!!! gear box problems! a4 b5 tdi help needed asap
    By benj in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th March 2011, 19:32
  3. Engine problems help needed ASAP
    By bellamy2010 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2011, 18:06
  4. HELP NEEDED ASAP!!!
    By supanova in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2010, 11:24
  5. S3 Grill Needed ASAP
    By Paul @ Unit in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2009, 07:12
