AH FabricationsEM Tuning
Results 1 to 9 of 9
Thread: Steering wobble
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,592
    Steering wobble
    OK, looks like my car has got a new problem, I'm getting vibrations through the steering column whilst under braking when the brakes are hot! Is this a sign of warped disks anyone?
    Oct 2003
    South Wales
    2,942
    Re: Steering wobble
    Sounds like Joe [img]/ubbthreads/images/graemlins/thumbsdown.gif[/img]
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    Re: Steering wobble
    jojo,
    I've had this problem for a while now. I'm on my Third set of discs, as I've been told the previous Two sets were warped, not sure that is what the problem is though as I thought that if you had warped discs then the problem would have started from day one. If you find out what the problem was please post your solution.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,592
    Re: Steering wobble
    Forgot to add that I have the Brembo GT(junior) Kit fitted.
    recomdos's Avatar
    Feb 2004
    North East
    988
    Re: Steering wobble
    Jojo,
    not sure what the brembo's are like exactly - they drilled/grooved etc? but if they are grooved then I don't think they can be skimmed, my ebc's have the same symptoms, and I was told they could not be skimmed so a new set of discs will be needed....or nice upgrade if I can ever afford!
    I'd like to be told I was wrong and there is an alternative though!
    Rob [img]/ubbthreads/images/graemlins/smile.gif[/img]
    imported_velcrobix
    Re: Steering wobble
    I am also suffering from this problem.
    Soon to buy new discs i think.
    What do you think of these as standard replacements.??
    It only lists them on here for the A3 (will have to search site) but i think you can get them for the S3.
    http://www.gsfcarparts.com/brembo/
    hopper's Avatar
    Jan 2005
    stoke-on-trent
    122
    Re: Steering wobble
    just take them to an engineers and they will skin um for u. on my old corsa sri i had 2ltr brakes on it and warped 3 sets of disks, had 1 set skimmed and they were still on the car wen i sold it, once they have got that hot and warped they are hardened so skim them and they wont warp so easy
    Mar 2003
    68
    Re: Steering wobble
    Take it to AmD Technik at Bicester, just off the M40 so not too far from you
    www.amdtechnik.com
    They have a ProCut lathe which skims the disc while it is still on the car, so perfectly finished
    Costs about 50 per pair
    Have had it done on a couple of cars now and it is very effective
    Neil Birkitt
    Audi Driver mag
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,592
    Re: Steering wobble
    Thanks for the info Neil, but hoping to do it more locally, I would need 2 trips to AmD to get it sorted, as they have to diagnose warped disks before they will book me in. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
