Monster MotorsportBadger5
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    Haldex fualt code
    My code came back so i can copy it onto here now. Going to do the oil and filter next week if i can and see if that does anything.
    VCDS-Lite Version: Release 1.0
    Sunday, 23 October 2011, 10:06:04.
    Control Module Part Number: 02D 900 554 B
    Component and/or Version: HALDEX LSC ECC 0006
    Software Coding:
    Work Shop Code:
    1 Fault Found:
    01155 - Clutch
    04-10 - Mechanical Malfunction - Intermittent
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,573
    This was mentioned recently iirc... its an indication of imminent haldex clutch pack failure due to infrequent oil changes...
    If you haven't had it done then get a haldex oil and filter change pronto...
    <tuffty/>
    May 2008
    perth
    1,197
    The haldex clutch is part of the diff isnt it? So if an oil and filter change dont fix it its new diff time is it?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,573
    Haldex unit is bolted onto the rear diff and can be bought separately but you could try eBay etc if it comes to that
    <tuffty/>
    BENJAMIN's Avatar
    Mar 2011
    472
    You can buy the clutch plates as a set from the dealer for about £120! However I personally haven't plucked up the courage to strip it down and replace them yet, a second hand diff was the easier option. Also worth checking that your haldex pump is working, it's bolted to the lower front right corner of the diff, you can activate it in output tests on vagcom, if it buzzes strongly then it's probably good.
    May 2008
    perth
    1,197
    I went to try the output test but my lead won't let me do it. If it is the clutch I would prob get a seccond hand unit and maybe repair the old one. Or even get a goosed one to fix then swap over.
  1. Haldex ECU - Fault Code J492
    By Jonay in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th December 2011, 16:26
  2. I got a fault code - help please. Code 18057.
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2011, 10:29
  3. what gearbox code matches engine code ASV
    By sjfedex in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2010, 19:18
  4. Replies: 5
    Last Post: 18th January 2010, 23:36
  5. Haldex?
    By PA0L0 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2009, 09:54
