Monster MotorsportBadger5
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: Haldex oil and rear diff oil help ?
    Sep 2011
    66
    Question Haldex oil and rear diff oil help ?
    Hi people,
    Well i have changed my front gearbox oil in the s3 and what a change it made feels much better, Well tomoro im going to do the haldex oil change and the filter, The guy on the phone at audi said there no oil in the rear diff he said its used by the haldex oil ?
    Im confused because i though there different oil in the rear diff.
    Can someone help, im new to this ..
    i know the haldex oil is drained by the drain plug and then refeild by the drain plug.
    cheers
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    I think Audi are wrong...
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    Sep 2011
    66
    I know there rong anyone can help me with my question as i need to get it done tomoro
    kind regards
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Rear diff and haldex are seperate bits... rear diff uses the same gearbox oil the front does (75w90 semi or fully synth)... the haldex uses a special hydraulic oil... its drained and filled from the little drain on the bottom of the haldex clutch... you have to warm the oil by driving the car for a few minutes so it comes out properly... the filter is tucked up on the side of the haldex unit requiring a special spanner to loosen and tighten
    <tuffty/>
    Daniel Thomson likes this.
    Sep 2011
    66
    Cheers just didnt want to put the oil in the rong place..
    anyone has any pics off the rear diff drain and refill plugs ?
    thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Rear diff drain plug is bottom right looking from the rear of the car looking to the front... fill plug is pointing towards the front of the car 90 degrees up from the drain... use penatrating fluid and undo the fill plug before trying the drain... nothing worse than draining all the oil only to find you can't undo the fill plug
    You can see the drain and fill plugs in this pic...
    both are opposite where the exhaust runs... haldex drain/fill is the small one on the silver bit between the propshaft coupling and the black beam of the rear subframe where the ties bars attach
    <tuffty/>
    Aug 2011
    124
    So this oil? AG 052 145 A1 - Diff Oil - 3 x 0.5ltr bottles £8.75 excl VAT each
    Is the right stuff for the diff?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Quote Originally Posted by DAZ1985 View Post
    If you mean the actual diff and not the haldex then its 75W90 semi or fully sythetic... I used this for both the rear diff and gearbox..
    Fuchs TITAN GEAR SYN 75W-90 Semi Synthetic Driveline Oil
    Haldex oil comes in a tube much like silicon sealant..
    More info here...
    AudiWorld Tech Articles
    <tuffty/>
  1. S3 rear haldex / diff leaking oil
    By mattandrew in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th December 2012, 11:52
  2. S3 engine oil, transmission oil, haldex oil, rear dif oil and front dif oil?
    By colicabcadam in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2010, 17:49
  3. Rear diff oil? (not haldex)
    By S3-Oski in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2009, 08:32
  4. difference between Haldex Oil and Diff Oil
    By V.I.P_UAE in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2009, 10:40
  5. A3 Quattro Rear Diff/Haldex Coupling Oil Change
    By imported_rob911 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 10:50
