Badger5AH Fabrications
Results 1 to 12 of 12
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    centre cap size? and trye size?
    hi all,
    well last night i went and picked up a set of wheels. which to day i dropped off for reburbing.
    they don't come with centre caps so wondering if anyone on here knows the size? i have posted on the rs6 forum too as they're rs6 wheels.
    also two tyres are 225/35/19 the other two are 235/35/19. all four tyres are brand new. i assume they should all be the same size?? others wise the awd might be confused right? or is it ok to run a larger circumference on the back than the front?
    this is one of the wheels:
    cheers guys
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Thats only 3mm rolling radius difference that will be fine!,and as for the center caps id just go to audi and get new one's take the wheel part number,be around £35 £40!
    Audi S3- 1.8T Quattro
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    yeah i thought about that but theyre reps. cheers for info on the 3mm diff. being ok. is it better to put the 235's on the back? or front?
    im assuming these wheels will sit further in the arch? as they are ET35? might have to get some spacers too. are these ones alright? or to much?
    TT Shop - 15mm / 20mm Complete Wheel Spacer Kit - Including Bolts and Lockers - Audi TT Coupe and Audi TT Roadster Parts, Accessories, Styling and Performance Tuning
    or these that are smaller set
    TT Shop - 12mm / 15mm Complete Wheel Spacer Kit - Including Bolts and Lockers - Audi TT Coupe and Audi TT Roadster Parts, Accessories, Styling and Performance Tuning
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Are they genuine or replica wheels?
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    replica i believe. couldnt see an audi stamp on them
    Alex C's Avatar
    Lizard, Cornwall
    2,599
    I guess that a 3.5 mm rolling radius difference is comparable to worn tyres on the front with new tyres on the rear so probably shouldnt be worried about to much.
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    thats true. ill just stick the larger tyres on the rear.
    just gotta try and get some of these centre caps now, proving to be a right night mare
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Yea bigger on the rear!,35et is further outwards,et 50 is neutral neither innor out!,and id still go to audi they should be the same even if rep's!!
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    Alex C's Avatar
    Lizard, Cornwall
    2,599
    Quote Originally Posted by liquids3 View Post
    ? ET 50 means that the mounting face of the wheel is 50mm outside the centre line of the wheel. ET 0 means that it is bang in the middle
    Alex S3 AMK
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Yea but he asked if et35 sits further in the arch it does'nt sits more out,if it was et50 it would be more inward neutral!
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    JtotheD's Avatar
    Events Moderator
    May 2011
    Bournemouth, Dorset/ Wallingord, Oxon
    907
    I don't have these exact wheels, but i just got blank centre caps for my rs4 reps on ebay, then got a friend of mine who does signage and decals etc to make me some audi signs to stick on. been on there 4 months now and been brilliant, can't even tell the difference. i'll try get some pics up later.
    S3 8L Ming Blue 273bhp & 294lbft h
    Build/project thread
    check it out!
    Alex C's Avatar
    Lizard, Cornwall
    2,599
    ah ok. So how wide are the rims?
    Alex S3 AMK
  1. Centre cap size?
    By S3featesV9 in forum RS6 Forum
    Last Post: 27th October 2011, 19:15
  2. A3 BBS Pescaras - Centre Cap Size?
    By mattyboy84 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th May 2011, 12:34
  3. Centre Hub Nut size
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th August 2010, 12:25
  4. Bolero centre cap size
    By heymynameismark in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st October 2009, 18:12
  5. centre bore size?
    By strictlyVAG in forum Handling
    Last Post: 6th September 2006, 18:33
