Results 1 to 7 of 7
    lloydsta101's Avatar
    Bristol
    134
    Is this the 'Oil Temp' warning light? Also, need help with other stuff!
    Hi all,
    Can anyone shed some light please? I've been getting what I'm assuming is the Oil Temp light on the dash recently. It's coming on nearly every morning now... about 10 seconds after the car has been started (cold start). It beeps and flashes, then goes off after about 2 minutes.
    [IMG][/IMG]
    I have various similar problems that all seem to be related. My MPG is terrible considering the way I drive the car, I never see over 19 MPG despite my desperate attempts at economical driving over the last year. I have to put a litre of oil in every other month... I've checked and there is no apparent oil leak. I had the Coolant Temp Sensor changed last week and there has been no change.
    Also, I've mentioned this before but the engine fan has a mind of its own... it spools up whenever it feels like it (can be as soon as the car has been started or 2 hours later), but it doesn't stay on. It will go on an off every 3-4 seconds until I turn the ignition off the other end.
    Any information/suggestions are greatly appreciated.
    Current: 2007 Audi A3 2.0 TDI (Black)
    Previous: 2000 Audi S3 (Silver)
    Previous: 2003 VW Golf R32 (Blue)
    Alex C's Avatar
    Lizard, Cornwall
    2,600
    its the "coolant level to low" light
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Its not oil temp!!
    Check your header tank, you either need to put some water in it or sensor in the header tank has failed. Easy to sort if it has as you change the whole pot for about £15.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Bristol
    134
    Ha ha, duh! I've never seen that warning light before so was unsure. I'll take a look and see if it needs any, hopefully it will be as simple as topping it up.
    Any ideas about the other issues? Would be nice to get the fan fixed; it's getting very annoying now.
    Cheers for the replies!
    Smokey_clark's Avatar
    12th Gear
    Nr Bath
    211
    Does your car warm up and stay at 90?
    Bristol
    134
    Yup, I don't drive very far during the week (I work about 2.5 miles from my house) but it always manages to get up to 90 and stays there.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Does the warning light only come on when you start the car from cold?
  1. Oil Warning Light / Coolant Warning Light / Coolant Leak
    By KV72 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th September 2010, 20:32
  2. Oil warning light on?
    By sprally in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2010, 02:58
  3. Oil level low warning light - what oil to buy, on xmas day?
    By drewbee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th December 2009, 11:32
  4. Oil Warning Light - Again!!
    By NICKY_CDN in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th February 2009, 11:51
  5. Oil warning light?
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2009, 20:00
