Sky InsuranceJMB Retrofits
Thread: 1.8T engines
    Apr 2011
    Dublin, Ireland
    621
    1.8T engines
    Are all the 1.8T engine blocks the same. Could I fit an APY block etc to a BAM head.
    Thanks.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
    RIP S3dave
    May 2004
    nr Glos
    7,195
    yes
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    +1...... I think people tend to go for the AGU as it large ported head.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    210/225 blocks are supposed to have extra strengthening in the webbing but as Bill said all the 06A blocks are interchangable with any 20v head... you can't use inline blocks (058/06B) though but you can use inline 20v heads on transverse blocks...
    Be aware of compression ratio differences if you plan to use pistons from a doner block and there are some valve train differences between some heads (noticed on an AMK to AEB head swap where valve collet grooves were different)...
    <tuffty/>
    Apr 2011
    Dublin, Ireland
    621
    Good news then. I am hoping to pick up a block from a scrapper next week and build it up over the winter. Thinking high comp 2.0l stroker.
  1. difference between 1.8T engines
    By sam4191 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th March 2010, 12:41
  2. New Engines
    By rwest in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 23rd June 2008, 15:08
  3. Engines
    By pav767 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2008, 14:50
  4. Engines Let go!
    By D8UGF in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th January 2008, 20:41
  5. engines
    By markus2 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th January 2004, 01:06
