Monster MotorsportEM Tuning
    Maz
    Maz's Avatar
    Moon is made of green cheese
    Jan 2005
    East
    1,008
    ...Help, electrical / brake lights issue nightmare!
    Evening all,
    It's cold, dark, my hands are shredded and I'm about to set light to the car if i can’t get it sorted.
    This all started with the little bulb warning with the x in the middle light up on the dash this past week. I noticed the passenger side brake light wasn't working. Tried to change it over the weekend, it worked for a second then stopped working after I’d bolted everything back up again, typical. I have a mac sub back there as well so that makes things even more tricky as there isn’t enough room to access the bulbs without taking the rear lens off.
    Thought the bulb may have been faulty so picked up a few more today and attempted again, still no luck...
    At the moment when I press the brake pedal with headlights switched off the passenger side still doesn't work. The drivers side brake light and the high level one work fine although it also flashes the front drivers side beam when the pedal is pressed... lol
    With headlights switched on the passenger side not lighting up at all but the drivers side and high level brake light stay permanently on.
    …I’m thinking it’s either got to be crappy bulbs or brake light switch, what do you guys think?
    Mineral Grey [
    AMK
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    Have you scanned the car? Normally VCDS will flag up if the brake light switch is at fault.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    No, don't have it.
    Thing is I changed the brake light switch early this year, it can't have failed already???
    Mineral Grey [
    AMK
    Westy's Avatar
    Dec 2008
    17,264
    Quote Originally Posted by Maz View Post
    No, don't have it.
    To be honest mate if it was the brake light switch all your brake lights would be behaving the same, as in none of them lighting up when you press the brake pedal.
    S3 Build Thread
  1. Electrical/Power loss issue...
    By E2FAS in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2011, 22:19
  2. Electrical issue !!!
    By jimiboboyo in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2010, 14:22
  3. brake lights issue
    By dares_uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2009, 15:23
  4. electrical problems (mirrors and interior lights)
    By afcjay in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2008, 13:24
  5. No brake lights (Switch issue)
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2008, 13:07
