JMB RetrofitsEM Tuning
    S3 Paul's Avatar
    Oct 2006
    2,764
    Vag Com fault code comes and goes...00526 brake light switch F implausible signal
    As above realy, This code comes and goes and the car feels a little flat when its there,
    I do have the dash brake light out warning from time to time as my drivers side rear light some times doesnt come on... but then next press it works.
    Ive looked it up on Ross Tec site and it says what might cause the code but not if it would make the car hold back.
    Is this likely and is it worth just trying the bulb or should i buy a switch too?
    Noggy Blue 2001 S3
    Jul 2006
    Crewe
    93
    I'd replace the bulb, the filament sounds like it's on it's way out.
    I've also had to change the brake pedal switch due to no brake lights a couple of years ago.
    Jul 2006
    Crewe
    93
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Brake light switch is only £10 from the stealers (i got one last week) and takes about 30mins to fit as i took off the trim below the steering wheel to make access easy.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
  1. 16575 - Fuel Pressure Sensor (G247) Implausible Signal
    By jb0o in forum VCDS (formerly VAG-COM) forum
    Last Post: 31st March 2014, 01:42
  2. Steering Angle Sensor - Implausible signal
    By Wrath in forum VCDS (formerly VAG-COM) forum
    Last Post: 16th August 2010, 23:07
  3. EGT Sensor implausible signal fault.
    By sean_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2010, 11:18
  4. Front Signal and Rear Brake Light Errors
    By vpg_ii in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th December 2004, 05:34
