JMB RetrofitsSky Insurance
Results 1 to 11 of 11
    Oct 2011
    23
    New member, few questions
    Hi all
    Recently bought a 2001 a3 1.8t (104000) and am thinking of doing an oil change only on it, as the colour seems to be a bit dark.
    Whats the recommended oil for these cars?
    The other two things are the rear windscreen wiper has stopped working just recently, would this be the motor, or a loose connection? (the fuse is fine), and the subwoofer in the boot compartment is not working. Is this connected to the head unit? The guy I had it off needed to get the serial code off the unit and I was thinking he may have knocked the connection out?
    Any advice would be greatly appreciated and I think they have the smoothest engines ever!
    Thanks, mark.
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    dunno about the other crap but the recommended oil is quantum fully synthetic 5w 40 (recommended for those with a fair few miles, so your car will be better off with this) or 5w 30.
    Id ask the sub question in the audio forum. Will get a better answer in there for sure.
    edit: Forgot to say you can get oil from stealers or TPS (the parts specialist) for around £16 for 5 litres
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    May 2010
    Bedford
    2,877
    Unless TPS are giving it away at stupidly cheap prices is £33.94 inc vat
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    s3schofield's Avatar
    Sep 2009
    Burnley Lancs
    129
    any good make 5 30 w fully synthetic will do get a magnetic sump plug while your at it too
    Seat Leon Magnetic Sump Plug, 1.8T Curpa R | eBay
    Audi S3 8L 2001 imola yellow autobahn tip, heatshield, metal mesh cone filter, apr r1 DV, REVO stage1, SPS box, Weitec coilovers, forge short shift kit, bosch aero wipers, 20mm rear spacers Wanted 3"Dp Decat rear arms pm me
    my progress thread http://www.audi-sport.net/vb/a3-s3-f...ss-thread.html
    Sep 2009
    Burnley Lancs
    129
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    Quote Originally Posted by Jason.s View Post
    thats what it cost me from tps mate a few others have had the same sucess aswell. is it really double at the stealers?
    May 2010
    Bedford
    2,877
    It costs US the dealer £19quid from VAG lol. TPS get it cheaper from VW but dont always cut the retail prices to match so sometimes making huge margins on parts.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    if youve just bought the car, and likely have no idea of its past oil changes, id do what alot of new owners do and are recomended by people on here,
    and that is change the pick up pipe in the sump, available from audi for about £10, and clean out the sump, and do an oil flush with an oil flush chemical. refit and new oil in.
    its a wise move seeing as audis have 'long life servicing' which is oil changes every 20k, which is just silly.
    you wont believe how clogged the pick up pipe can get, and it could potwentially cause oil starvation and kill your engine.
    im surprised no one has mentioned it already!
    Oct 2011
    23
    Thanks for the advice. Your much more help than the people on the mx5 forum lol.
    Ill consider doing the pipe, but can it be done easy by your average joe?
    I think it needs a temp sensor too as the temp needle shows 90 then drops to 70 continuously.
    Is this normal?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    does the temp drop suddenly then go back up suddenly?
    its likely temp sensor yeh, not a big or expensive fix.
    the pick up pipe isnt a hugely difficult job, adds another hour or so onto an oil change.
    Oct 2011
    23
    Kind of, its all over the place really. Some days when driving to work (mainly motorway) it never rises above 70. I always thought this was because the engine was being fed plenty of cold air at motorway speeds and low revs, but I have heard off many people it should stay at 90. Ill try a sensor, and give the pipe a go. Hopefully my haynes manual will guide me through it
  1. New member with a few questions
    By tongy in forum The Welcome Section
    Last Post: 16th January 2010, 20:30
  2. New Member with some questions for S3 8P...
    By gnic13 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th November 2009, 22:07
  3. New member-few questions.
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2009, 01:22
  4. New member, Hello! Few questions
    By phill1.8T in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2006, 20:01
  5. New member Questions
    By W8 Performance in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2004, 20:56
