Volks AutosChris Nott
Results 1 to 39 of 39
    Oct 2004
    45
    Fitting S3 seats
    im getting an S3 interior very soon does anyone have any fitting insructions im fitting them in to my 98 A3 1.6 SE will the airbag connecters just plug in or will i need 2 get new connecters or join them of some sort as the S3 interior is from a 2002 car many thanks
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Re: Fitting S3 seats
    think you might have more fun than your banking on with this one... are the seats heated? if they are then there's not just the airbag connector, but also the heating connector and the power seat connector, could be fun to sort, good luck though, guess you need a wiring diagram for the seats, someone might have them on here???
    Oct 2004
    45
    nah they are not but im not taht bothered about teh heated seats i thought that i would jsut have to run a cable 2 a permanent or switched live from the seat/lumbar
    239
    as i understand it, if the airbag warning light is on none of the airbags will fire in a crash. removing the seats is very easy, remove the plastic trim covering the ends of the runners behind the seats, then undo the torx head bolts below the front of the seats, which hold to the car, then just slide them back and off the runners, unpluging the wires underneath when you can reach them.
    Oct 2004
    45
    TTT
    239
    yep just need power to be on the ignition, i took the power from the buss bar, behind the lower dash below the steering wheel, the yellow terminal on the left is the ignition live. From here you can either buy the correct wires from audi so you can have a fuse in the board in the side of the dash with the others, or just install a inline fuse. The run the wire to the seats using their existing earth. I thought your old seats were already powered, so wouldn't need new wiring?
    As for airbags, i took mine S3 seats out at weekend to have a look at plugs. Connecting new plugs isn't the difficult part, like you say can get new ones from audi to replace seat ones so the car loom isn't cut. The difficult part is that the wire colours on the s3 seats aren't the same as on the car, so isn't as easy as just connecting red to red.
    Car has combination of yellow and green striped wires, And brown earth
    both seats have a brown earth
    s3 seats have a blue and a black wire
    a3 seats have a blue and another thinner brown wire
    now you would think the blues match up and therefore the black and brown belong together?!!!
    sounded a bit too risky to guess i thought!! so i put a 4.7 ohm resistor in the cars plug and reset with vagcom, so the other bags will work til i ask a electrician friend of mine.
    another safety point with airbags, static electricity can set them off!!!! also if you do replace the plugs ensure you don't touch the wires together, at any point!!! could get messy!!!!!!!!!
    Oct 2004
    45
    many thanks settle does anyone else no the colours to math them up then
    Oct 2004
    45
    Bump!
    Oct 2003
    Channel Islands
    213
    Settle, did you get anywhere with matching up the wires?
    239
    to be honest i haven't bothered, i'm selling the car with the s3 seats in it and don't wanna mess anything up with it. BromleyA3, the resistor just sits in the plug on the car, two contacts on the plug, one end of the resistor into each contact, easy as that.
    Oct 2004
    45
    then will the airbag light have to be re set or will it just not go on many thanks settle
    Oct 2004
    45
    khufu so are u saying the green wire goes with the black wire and the white wire goes with the blue wire and brown wire goes with brown wire ?????
    Khufu's Avatar
    West coast of Scotland
    5,693
    according to WinElsa, I will try to get the PDF for you - its a pain that you cant link to a pic/file off of your hard drive anymore.
    239
    thanks khufu, that looks like the wire colours of the a3 seats, don't suppose you have a similar diagram but of a latter spec s3??
    Khufu's Avatar
    5,693
    This is off of a 2001 with recaros..
    http://myweb.tiscali.co.uk/macnee/s28l_1-2_17.pdf
    Oct 2004
    109
    right as i may be able to get some S3 interior was wondering about this resistor? where from how much and what does it look like? if its got a part number or code which am i after?
    239
    thanks khufu i'll digest that pdf and see if i can figure out wires
    the resistors cost 14p for the pair from Maplins, there website is www.maplin.co.uk find your nearest store and just ask them for a 4.7 ohm resistor, just make sure you as for a 4.7 ohm not 4.7k.
    Oct 2003
    Channel Islands
    213
    I shall be attempting to fit my new interior this weekend. I have no electric lumbar adjustment, so I will be running an ignition live to the front seats.
    What ampage in-line fuse should i use?
    Oct 2003
    Channel Islands
    213
    Anyone?
    239
    leddy a 10 amp fuse should be fine
    239
    also leddy i've just noticed your car is a 2002 spec, now i'm unsure what interior you've bought but guess it's an s3 one, in which case you might find you don't have any airbag connector problems that i had because later A3's have the same connectors as S3's, goodluck with the change over
    Oct 2003
    Channel Islands
    213
    [ QUOTE ]
    [/ QUOTE ]
    That would be a real bonus, I won't know until I've got everything stripped really. The other fortunate thing is that the seller included the car end of the loom so I have the S3 plugs if I need to do some on-the-fly rewiring!
    The only tricky bit will be running power to the seats, i'm planning on breaking into the switched live at the fuse box, though this is already feeding the headunit and my bluetooth hands free kit - do you think this is okay or should i break into the hot side of that fuse and put my own inline fuse?
    Oct 2003
    Channel Islands
    213
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    You should be carefull doing any rewiring on the original airbag wiring. Authorized Audi personal are not allowed to do this; they have to remove the hole loom and replace it with a new one. (a thing to think about if you're going to sell your car [img]/ubbthreads/images/graemlins/wink.gif[/img]
    [/ QUOTE ]
    Thanks for the words of warning! I am only going to plug them straight in if the plugs are the same on my car as the plugs on the seats (as Settle pointed out, there is a good chance they are due to the year of my car). If they aren't, i'll leave the airbags unplugged, and take the car to my local specialist on Monday and let it be their problem!
    Any ideas on the ignition live feed I mentioned above?
    239
    i would definately go on to the switched feed on the buss bar, its rated for 75amps, i think, so running the headunit, bluetooth and seats should be fine.
    what are the new seats like? full leather, half leather? colour combination?
    239
    also are you going to wire up the heating?
    Oct 2003
    Channel Islands
    213
    The seats are grey full leather S3 items, and for the moment i'll leave the heating as I haven't had a good think about where to locate the switches. There is a thread in here regarding the blanks either side of the esp switch that would be ideal, but I don't think anyone knows any good OEM switches that will fit there. [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Btw, the fuse in the SKontact feed is 10amps I think, would this be groovy for all the items that will be hanging off it?
    I'll be sure to post pics when finished [img]/ubbthreads/images/graemlins/cool.gif[/img]
  28. #27
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    So Leddy what are you doing with your old seats? Also what colour are they?
  29. #28
    Oct 2003
    Channel Islands
    213
    [ QUOTE ]
    [/ QUOTE ]
    They are anthracite, was going to stick them on ebay as they are mint, unless someone on here wants them. I can get you some pics tomorrow if you want.
  30. #29
    Jan 2005
    60
    [ QUOTE ]
    i would definately go on to the switched feed on the buss bar, its rated for 75amps?
    [/ QUOTE ]
    Where is this 'buss bar'?
    regards
  31. #30
    Oct 2003
    Channel Islands
    213
    Right, everything fitted. Airbag plugs were the same so that was nic eand easy, ignition and earth was run from the fuse box. All electric amazingly worked first time.
    Front seats
    Rear seats
  32. #31
    Jan 2005
    60
    [ QUOTE ]
    [/ QUOTE ]
    Looks great!
    As I have S3 el recaros just waiting to get fitted; where did you run the cables? Did you buy a wire loom or did you create one yourself? (shouldn't be that hard) Where in the fuse box is ign-on found?
    regards
  33. #32
    Jun 2003
    Hythe, Kent
    1,180
    Look nice mate [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Kev.
  34. #33
    Oct 2003
    Channel Islands
    213
    As all the plugs were included with the seats, i just ran power and earth cables myself and joined them to the power plug. Ran the cables down from the fusebox under the carpet along the door sill and across under the carpet to where the airpug plugs come out.
    The connection you want at the fusebox is labeled Kontact-s in the handbook. If you do a search in the Ice section of this forum you should find a tutorial by AndyMac that shows you how to break into the correct fuse and it's likely location in the fusebox.
  35. #34
    Jan 2005
    60
    [ QUOTE ]
    [/ QUOTE ]
    Thanks a lot :-)
  36. #35
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    Hey Leddy,
    Seats are looking sweet. I wish I could nip-out and just grab a set right now! ...Maybe some day.
    Regards,
    Rob.
  37. #36
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,752
    does anyone know if S3 S4 seats are exactly the same?
    How easy are they to fit into a A4, anyone?
    My A4 has electric lumber support so how would i wire up the other movements.
  38. #37
    nervus's Avatar
    Apr 2004
    1,160
    S3 and S4 seats are essentially the same except the S4's dont have the forward tilt/release facility as in the 3-Door S3!
  39. #38
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,752
    Ok cool cheers.
    Anyone know about the electrics cos my standard ones are part electric (Lumber).
    239
    i'm not sure if your trying to fit S3 seats into a A4 or S4 seats? S4 will of course fit but i don't think S3 ones will?! pretty sure they have different runners, could get them changed i guess but would be expensive and effort?! but then i guess S4 seats are like rocking horse sh*t!
