EM TuningSky Insurance
Results 1 to 13 of 13
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Fault codes can anybody help ?
    Thanks to Scott - forum member sc00byd00byd00 a cracking guy I have now had the fault codes read on my car.The car has been running poorly losing boost and rough idling. So can somebody help identify the problem so that I can fix it and get on with my life.I am as always very grateful for any assistance.
    VCDS Version: Release 10.6.5
    Data version: 20110930
    Sunday,16,October,2011,16:28:07:12701
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    VIN:
    Address 01: Engine Labels: 06A-906-032-AUM.lbl
    Part No: 06A 906 032 DK
    Component: 1.8L R4/5VT 0001
    Coding: 11500
    Shop #: WSC 06435
    VCID: 6AD02A173CE4
    5 Faults Found:
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-00 - -
    17545 - Fuel Trim: Bank 1 (Add): System too Rich
    P1137 - 35-00 - -
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-10 - - - Intermittent
    16685 - Cylinder 1: Misfire Detected
    P0301 - 35-10 - - - Intermittent
    16686 - Cylinder 2: Misfire Detected
    P0302 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,612
    Looking at these they look related to each other...
    P1297 - 35-00 - -
    I think this is will come up if the boost deviation is too high in this case boost isn't reaching the ECU request... indicates a big leak...
    P1137 - 35-00 - -
    Typically a vacuum leak contributes to this... this is the short term/idle fuel trim... if its thrown this code its sucking in air big time and has gone passed its 25% adaption limit in adding fuel... a look on block 32 will say for sure..
    Normally the result of a air leak causing the afr to go rich from too much fuel so ends up with soiled plugs and multiple misfires... I suspect at some point your car has sounded like a poorly scooby...
    As you may have noticed, the common thing here is 'leak'... a big one... probably a pipe under the inlet mani somewhere... if you can't spot it then get a smoke test done...
    <tuffty/>
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Thanks tuffty you clearly know your stuff I have noticed a strong smell of petrol when running rough. I am struggling with some of the terminology how do I look at block 32 and what is a smoke test ?
    Thanks again.
    Just been thinking about the last time the rough running happened and it was following a fast drive home when I had just carried out an overtake.I assume therefore the turbo was boosting pretty highly and this would indicate a leak as it must have been sucking in air ?
    Last edited by <tuffty/>; 17th October 2011 at 07:11. Reason: I'm not Badger Bill :)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,612
    Use VCDS (vagcom) to look at block 032 in the engine module... anyone conversant with VCDS should be able to help your here... a smoke test will reveal leaks however small by pumping smoke at a small amount of pressure into the charge air/intake system... if there is a leak (baring in mind the intake and charge air system is supposed to be sealed as its under pressure when the turbo is working) then you will see the smoke coming out of wherever it is...
    Difficult to tell whats gone but my money is on the PCV pipes under the inlet manifold... this is usually noticeable with a lot of oil deposits over the outside of everything.... remember, oil is supposed to be on the inside of the engine not the outside... any oil on the outside suggests a leak...
    <tuffty/>
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Where are you in Cheshire? I'd be happy to take a look over the car for you if you are close
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    <tuffty/>
    Looks as if you are on to something here tuffty as I also posted for an opinion elsewhere and got the following reply. Im hoping its not the coil packs as they were replaced just a couple of months ago by Audi under warranty. I believe that breather hose is a ***** to replace being under the intake manifold.
    "That looks like a mixture of a split crankcase to manifold breather hose, dirty throttle body and possibly a failed coil pack, certainly I would expect the breather hose from the crankcase vent hose T piece valve to be split."
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Quote Originally Posted by SiGainey View Post
    Hey Si thats kind of you to offer but I am between jct 17 & 18 of the M6 which is Sandbach & Middlewich.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,612
    Quote Originally Posted by macpdm View Post
    They aren't that difficult to replace tbh... fiddly yes but easy enough for a diy'er
    <tuffty/>
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    This owner pulled these pipes out from under the intake manifold are these the hoses I should be looking at ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,612
    Yarp, something similar to that... that one in the pic will be a little different but the main one to look for is the one coming from the centre on the inlet mani (underneath) that feeds into the 3 way valve (pretty sure they fitted these to AUM)... it normally splits there and/or where it goes to the PCV valve coming from the block... there is a plastic elbow coming out of the block on top of the oil filter housing... this goes to a rubber t-piece that has the PCV valve in the top... the other side of this goes to a plastic pipe that connects to the rubber Y jobber on the cam cover...
    All of this 'rubber' stuff is prone to decay from oil and splitting...
    <tuffty/>
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Struth I think im gonna struggle to do this myself
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,612
    Its not as bad as it sounds but I guess it depends on how comfortable you are with doing these things...
    Not sure what else to suggest other than taking it to a specialist to have a look at...
    <tuffty/>
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Just a quick update
    Sandip came down to see if he could help me out. He was carrying a spare Miltek DV which we swopped over because my OEM valve just felt wrong when pushing it in and out with your finger and the code read mentioned checking the DV. We went for a long drive me giving it the beans and the car was perfect no sign of hesitation or loss of power. We did note that the thermostat needs changing as the temp sender was working correctly according to the readout on the AC as Sandip had set it up. We then put the old DV back on expecting the car to play up but annoyingly it did not. In conclusion Sandip found a kink in one of the hoses and we thought it was a combination of the stat and possible faulty DV. Sandip cleaned the MAF and checked the plugs and read the codes nothing was too much trouble.
    Like a lot of people I have met on here Sandip has to be one of the nicest most genuine guys I have met in a long time and would not take a penny off me for his time or fuel. Genuinely I would be proud to call him a friend.
  1. fault codes - please help
    By niaz7 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th April 2011, 16:58
  2. help with 1.8t fault codes please
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2010, 20:59
  3. fault codes
    By mad max in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2010, 21:49
  4. Fault codes help
    By Andy_S3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd December 2008, 20:27
  5. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
