Badger5AH Fabrications
Results 1 to 32 of 32
    Aug 2009
    Costa del Cardiff
    535
    Seized spark plug...FML
    If it snaps in the head, Im f****d. Car's misfiring quite badly under load in higher gears above 50mph too so it has to come out, but It's risky and Im unsure how to go about this =/
    Kaibo's Avatar
    Jun 2011
    Middlesex
    354
    Can't you book it in for a garage to change them, don't tell them it's seized, if it breaks then it's their problem?
    Aug 2009
    Costa del Cardiff
    535
    Possibly, but I would assume once they were unable to remove it, they would call me explaining that it may snap in the port and they would attempt to remove it but at my own risk. =/
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Soak k. Wd40 and slowly try to edge it out, shouldnt be seized though mate, you sure its not been cross threaded?
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    Second that one Dani......
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    I'd second the soaking it option, try plus gas... not too much.
    Oh, and did you really type FML?
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Aug 2009
    Costa del Cardiff
    535
    Quote Originally Posted by A3Tom View Post
    Cheers lads, I'll give it ago, how long should I leave to soak? Is it advisable to try to work it loose with a ratchet?
    Nov 2008
    154
    Just a thought: Are you trying to remove it with the engine hot, or cold? Whichever it is then try the other one, let it cool OR run it up to temperature.
    a3tdi2001's Avatar
    437
    It should be removed with the engine stone cold. The head expands when hot and will grip it more. Agree with the plusgas or some shock and unlock. To be honest mate you're better getting a mechanic to do it if you're unsure as they'll have a way of doing it if they're any good.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Let the car cool down and squirt some plusgas down the hole, you wont need a lot. Go away and have a brew/fag/sarnie whatever for 20 minutes and then have a go at it.
    I'd use a 16mm plug socket on an extension bar on a 1/2" ratchet but DO NOT GO MAD. If it doesnt come out then leave it.
    I've changed the plugs on my car this morning and used the above method without issue, although when I did them last time I didnt bollock them up and put a little smear of copper grease on the thread to aid release next time. Use the socket to put them back down the hole too so you know they go in straight.
    Did you put them in last time?, you only have to just nip them up. Sounds like someone has wellied it up too tight or wrecked the thread.
    Aug 2009
    Costa del Cardiff
    535
    I've only had the car since April, looks like the plugs have'nt been changed in years. Who ever fitted them was obviously a tool.
    "FML" has become a regular term for me since I bought the S3!
    My concern is, if I am unable to remove it, how is a garage going to?
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Ha, its the lingo of a petulant emo teenager :D
    Head off I reckon!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    Quote Originally Posted by Kaibo View Post
    <sarcasm>Brilliant advice!</sarcasm>
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    Quote Originally Posted by JoeD View Post
    Because they are more likely to have had this issue before and are usually equipped to fix issues like this...
    <tuffty/>
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    <tuffty/>
    what...like removing the DV?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    ANd then complain if the job goes wrong?
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by SiGainey View Post
    Yeah and poss get a poor apprentice sacked???
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    I had this on my s3. One plug was tight as feck. I just worked it back and forth with a bar and got it eventually. I was ****ting myself the whole time that the thread would be wrecked or it would snap.
    Aug 2009
    Costa del Cardiff
    535
    Cheers lads, got a guy who says he can remove it, hes aware of the situation and says it shouldnt be a problem. So fingers crossed by the end of the week the car should be back to running the way it should!
    Kaibo's Avatar
    Jun 2011
    Middlesex
    354
    Yeah and then he goes home and kills his family, for god sake it was a suggestion, if he does it himself and it goes wrong then it'l likely need a garage anyway, don't see a reason for "sarcasm".
    And as for the DV thread, I really apreciate the thread being closed Tuffty <sarcasm/> before I get to defend myself, your not aloud to swear but people can jump on somebody for asking a legitimate yes/no question, and that's what it was, a question, too chavvy for some?
    Clicky much, I love my car and really enjoy coming on a site with like minded people but it's soured because of an ignorant few, rant over, I feel better. Hope you sort the plug out.
    Kai
    eddieantifreeze's Avatar
    Jul 2011
    164
    Ive had this problem alot, never on my a3 but usually on audi engines (old school 5 cyl usually). Plus gas is the key! and gentle gentle, dont swing off it repeatidly and be aware of how hot your making the threads, doesnt take alot to produce loads of heat from the friction (hence lube).
    I will say balls are required and as someone else rightly said, you will be crapping yourself while doing it - but have faith, its gotta come out if it cross threaded or not!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    Yeah and then he goes home and kills his family, for god sake it was a suggestion...
    ...and a poor one at that... as someone that works at a garage I can tell you that it would be very much the problem of the owner and not the guy doing the work...
    ...and of course you are entitled to your opinion and to do what you like to your car but it is not really the sort of discussion that needs to carry on as its a pointless one... as I said before closing the thread, no one would ever recommend removing the DV and no tuner with any presence of mind would map a 20v turbo with out one fitted... you got your answer so I closed it before the discussion actually turned into a slanging match... you have nothing to defend...
    Kai
    soured because of an ignorant few? so you don't think this forum is being soured by ill conceived comments such as
    Oh dear....
    <tuffty/>
    Kaibo's Avatar
    Jun 2011
    Middlesex
    354
    Ok I hold my hands up to the advice being ill conceived, I'm mean no malice to anyone, but wouldn't it be easier to say that instead of being sarcastic, is there a need from yourself, someone who has a bit more standing on the site, I for one look up to you and other people that have such knowledge and skill.
    If somebody asked me directions to a pub that I didn't like I'd tell them the way, not start telling them they're wrong for wanting to go there. My point is, point out my misdoings by all means, but at least be fair and stop people from putting what ever they like to put you down when they haven't got the answers, I refer again to the DV post, I'll leave it at that, just unfortunate that I couldn't of said it on there.
    Thanks Kai
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    Ok I hold my hands up to the advice being ill conceived, I'm mean no malice to anyone, but wouldn't it be easier to say that instead of being sarcastic, is there a need from yourself, someone who has a bit more standing on the site, I for one look up to you and other people that have such knowledge and skill....
    Granted, the sarcasm thing wasn't one of my better responses as it did hit a nerve so for that I apologise...
    Thanks Kai
    Fair enough...
    <tuffty/>
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Homer Simpson
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    So..... is the plug still stuck?
  28. #27
    Aug 2009
    Costa del Cardiff
    535
    Not had the oppertunity to get it sorted yet, 16 hour shifts...killer -.- should be going to a garage at the end of the week. Hopefully all wil run smoothly, unlike the car atm whey!!
  29. #28
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Just be careful that when you get your car just how you want it not to drive it onto the road. You'll let clobbered within 24 hours by some retard and end up with a smashed up car
  30. #29
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Well Tom, I think we should collectively change your name to Jonny Raincloud!! lol
    Homer Simpson
  31. #30
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    lol, pay your car insurance and road tax but dont drive it on the road :P
    Alex S3 AMK
  32. #31
    Aug 2009
    Costa del Cardiff
    535
    LOL thanks for the advice Tom, there are plenty of tools on the road in Cardiff, so I always have to be on the ball when driving round.
  33. #32
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    It'd be about right at the minute.
    Just spend 2 hours in they physio dept at the hospital... hell hole!.
  1. spark plug help
    By gussyldr in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2010, 22:02
  2. Spark Plug life....
    By phoenixv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2010, 21:30
  3. SPARK PLUG HELP
    By m444ty p in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2009, 23:20
  4. Spark plug problem?
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th September 2008, 13:43
  5. spark plug change 1.8T - how to?
    By jazzyc in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th July 2007, 17:46
