    Dec 2010
    94
    starting issue when hot
    hi been having a few problems. when the car is cold e.t.c the car turns over and starts fine. when the engine is hot however sometimes you turn the key and its really slow and turning over then all of a sudden it will turn over fine and fire into life. the battery si fine all been tested. im guessing its the starter motor on the way out??
    a3tdi2001's Avatar
    437
    Apparently the starter motor suffers from heat soak from the engine/gearbox as written by another member on this site. This could well be causing the problem. May last a while before it gets any worse.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    any fault codes
    temp sensor caused this problem on my car.£5 fix
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
  1. Hot starting issue
    By vw754 in forum Volkswagen and other VAG
    Last Post: 15th October 2011, 20:54
  2. Issue starting
    By dirk technic in forum Diesel forum
    Last Post: 27th January 2009, 11:04
  3. When hot starting taking 8 sec+
    By dantdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2008, 14:29
  4. Help! A4 1.8t 2003 Hot starting problems
    By Mark L in forum General Technical / How To
    Last Post: 19th June 2008, 09:08
  5. Hot Ambient/Load Idleing issue (A3 1.8T)
    By Tallpaul in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2007, 16:31
