AH FabricationsSky Insurance
Results 1 to 9 of 9
    birmingham
    165
    remove aircon and all pipes/ rad
    hi all,
    What is needed to remove my air con on my audi s3 2000 apy,
    as it gets in the way with the turbo on top mount
    I don't really use it this is what I need to know
    1. Is there a belt that i can get from audi to delete air con pump ?
    2. can i just leave the sensor unplugged or will i need a resistor for it if so which one would it be the same as the second air pump removal ?
    Tony
    birmingham
    165
    Bump any one
    It's all in bits
    Apr 2006
    Bristol
    219
    I think these are the OEM belt specs - 06A 145 933 D (1120mm) - should be from a 1.8T without air con.
    Not sure about the need for a resistor, can't you get it deleted when mapping? - would be interested in what you do here though.
    Are you taking the heat exchanger out too?
    birmingham
    165
    Quote Originally Posted by tompearson View Post
    cheers mate
    im going to be taking all the pipes across the back off bulk head out
    the pump and also the rad so i can sit my intercooler more back
    im going to use 330ohs 10w resistors which should work fine
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    You having problems with clearance for the pipes Tony? I had to gently bend mine out the way for fitment.
    Audi S3 1.9 GT30....
    ....that is all
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    I took mine out last month!,yea just get non aircon belt got mine from t.p.s,you can take the pipes out as one unit,and i just left the plug unattatched!,alot less weight and more space happy days!
    Audi S3- 1.8T Quattro
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    birmingham
    165
    Quote Originally Posted by MUSH View Post
    yh mate ive tired to move it but turbo still hits pipes going to get it all gone less weight
    plus im fitting my agu head so i can get it all out
    hows yours mate
    birmingham
    165
    Quote Originally Posted by liquids3 View Post
    have you got part number mate
    cheers
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Quote Originally Posted by tony696 View Post
    cheers
    I have'nt sorry mate did'nt keep receipt!,think someone did state it (earlyer post),if not just ask them to go on computer and find non aircon 8l chasis belt!
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
  1. Rad Leak
    By dex140 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2011, 10:21
  2. Anyone fitted a rad to their s3 ?
    By motfree in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2010, 16:58
  3. S3 rad ...
    Last Post: 29th November 2010, 22:43
  4. Removing aircon to remove phone cradle
    By Remains in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th May 2010, 15:29
  5. AIRCON Working until pipes freeze
    By rockfanatic in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th October 2007, 23:22
