Chris NottAH Fabrications
Results 1 to 9 of 9
    Sep 2010
    498
    Front ARB bushes need changing
    I have a 52 reg A3 TDI Quattro. The front ARB bushes need replacing. I have seen different sizes (18mm,19mm,21mm) mentioned. Can anyone confirm which size I need?
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Best just to go to Audi m8. Assuming you have a standard ARB, they will be able to do a lookup on your VIN and tell you which is the right part
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    Sep 2010
    498
    Cool, so do they supply the new bolts and brackets too?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    It's normally easier just to get a full new ARB for around £70 as the collars tend to break.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    May 2010
    Bedford
    2,877
    They can supply bolts and clamps but they wont come with the bushes. All seperate. VIN supplied will tell you what sizes are needed
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    a3tdi2001's Avatar
    437
    Pretty sure they made an updated bush with a smaller hole to replace the plastic collar which can then be removed and put in the bin where it belongs. Any chance you could post the prices and part numbers if you phone the dealers as I'm after a set myself? Cheers.
    Sep 2010
    498
    Thanks for the help people. I shall phone them up soon and report back.
    Apr 2010
    35
    Just measure the ARB with some vernier calilipers, don't even need the wheels off.
    Get some longer bolts, (the balljoint to wishbone ones do well) Makes it much easier
    Sep 2010
    498
    OMG didn't think of that! Thanks
  1. Changing front ARB Bushes
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st October 2011, 08:32
  2. Ebay front ARB bushes
    By nick4501 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2010, 11:53
  3. Front ARB bushes ??
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2010, 20:33
  4. Front ARB Bushes
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th January 2010, 22:18
  5. Front ARB Bushes - What size!
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2009, 19:02
