Sky InsuranceVolks Autos
    Jul 2011
    Very north of England
    42
    How do you get the nearside rear light bracket out?
    Hi I've tried to change nearside brake bulb but can't get the bracket out. There seems to be a plate in the way. Am I doing something stupid or should I remove the plate? I assume the big box underneath is an amp! Is it? Why so big?
    Taff
    Ps it's a 2001
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    Does it look like that?
    If so where the black connector is there 2 grey things either side of that press them in it should pop off the grey panel sits inside the red bit.
    Don't no what the other thing is it's not a amp thoe I don't think.
    IF IN DOUBT FLAT OUT---iF U AINT RUBBIN U AINT DUBBIN
    Jul 2011
    42
    Cheers Wayne. Thanks mate. I've done the off side but the n/s bulb holder bangs against a plate which sits above a big box, which I'm assuming in an amp. Not enough room for the bulb holder to move out as the bulbs don't clear the red bit!
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    Just looked at mine now it's a bit tight but does come out I've no black box amp thingy on that side thoe just the wheel arch.
    a3tdi2001's Avatar
    437
    http://www.tyresmoke.net/attachments...28Small%29.JPG
    The black box is a subwoofer for the stereo. The plate might be a part of the cd changer holding bracket I think. It does come out as it is but it's a bit tight. You have to press the clips as above but tilt the bulb holder so that you are pulling the bottom edge of it away first.
  1. Allroad nearside rear door lock won't work using central locking! Help!
    By buftonian in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th January 2011, 22:07
  2. Uneven rear nearside tyre wear
    By snottie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th June 2010, 06:05
  3. Loud Squeaking Noise (Nearside Rear)
    By Els in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2010, 22:36
  4. Rear Bushes and Centre Box Bracket
    By audi lover in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2010, 17:19
  5. Help! Rear Oil Seal Replacement B5 Quattro Nearside
    By RogerTDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th November 2009, 10:20
