Chris NottAH Fabrications
Results 1 to 22 of 22
Thread: Boost Problem
    Oct 2011
    Somewhere?
    147
    Boost Problem
    Hi everyone am now to the sight as i have just bought a 2000 audi S3 engine code APY. The car was fine when i got it a month ago but since about 2 weeks ago i has been having problems boosting. Its fine driving normal but as soon as the turbo tries to kick in it feels like its trying to but but somethings stopping it, it just judders and doesn't go anywhere. My dump valve has started to chatter when letting off the throttle as well and also has started back firing now and then.
    I have had it on Vag-com and it brought up the N75 valve what i have changed, the air flow sensor wat i have now changed and the N249 what has now been by passed, i also took off my forge p007 dump valve and fitted the standard one. I have unplugged the battery for about an hour or so to reset the ECU, put it back on Vag-com and no faults were coming up but i am still having the boost problems as i was before hand.
    The car has a full through miltec exhaust with sports cats, K&N cone filter and a custom map, not sure on what map it is tho?
    Any help would be appreciated.
    Buzzer's Avatar
    Apr 2011
    Dublin
    410
    Get a smoke test done to see if you have any leaks or splits in the vacuum hoses etc. Common enough problem on S3 of that age.
    When people get a performance car, the routine is to Kane it a bit more than usual ( novelty factor) and this will throw up some weaknesses
    Oct 2011
    Somewhere?
    147
    How is a smoke test done and can any garage do one? Could it be a faulty actuator thats making it struggle to get boost?
    RIP S3dave
    May 2004
    nr Glos
    7,175
    do you have a boost gauge in the car or liqui gauge or access to vagcom at all?
    If you unplug the N75 valve electrically, it should boost at 5-6psi.. If it does that then the actuator would seem to support normal boost for being run in "actuator only" mode.
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Buzzer's Avatar
    Apr 2011
    Dublin
    410
    Quote Originally Posted by Eddy_s3 View Post
    Smoke test can be carried out in alot of decent garages. Using smoke to find small leaks and splits where it might take hours to find otherwise. Quick and cheap.
    Smokepro introduction
    Oct 2011
    Somewhere?
    147
    Looks easy enoght to fo myself the smoke test.
    I have just plugged my boost guage in and the car is over boosting as hish as 25psi, when i unplug the N75 valve it stops this and only boosts to 5psi. Any suggestions on how i can stop the over boosting?
    Oct 2011
    Somewhere?
    147
    Any body help with my over boost problem? Any idea why its doing it and how to stop it?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Hi Eddy, overboosting does normally point to N75 or pipework leading to it. Is the new N75 a genuine valve from the dealer?
    Have you got any boost creep? Unplug N75, 3rd pull to red line and keep an eye on the boost gauge, it should stay at 5psi all the way to redline. If you have creep at around 5000rpm onwards your boost will start to increase
    Oct 2011
    Somewhere?
    147
    I got the N75 off a mate who said it was a working one of his ibiza cupra R, He said he changed the one on his because of boost problems and the new one didn’t make any difference.
    I have been messing on with the car tonight and bypassed the N75 with a manual boost controller what i had lying around and now its boosting fine at 18psi and running well. what i have done is left the N75 plugged into the air filter pipe and the other two pipes on the N75 i joined together and fitted the boost control from the top boost pipe to the actuator.
    I have drew up a crap diogram of how i have done it but you get the idea if you can understand it.
    Oct 2011
    Somewhere?
    147
    By passed my N75 valve tonight with a manual boost controller, Now its running fine with 16psi boost. I posted up a diogram of what i done but needs to be approved by the mod before it goes up :/
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Well if you fitted a new n75 valve but them you fitted a manual boost controller, id say you had the n75 fitted incorrectly.
    Oct 2011
    Somewhere?
    147
    Its fitted right, Fitted exactley the same way as the old one came off, it was a 2nd hand N75 that i fitted but am off to audi tomorrow to pick up a brand new one so see if that makes a difference.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Ok mate, easy enough to fit wrong, i had mine fitted wrong for over 12 months lol.
    Yeah id try a new n75 valve.
    Oct 2011
    Somewhere?
    147
    Got it back down to DPM Performance an saturday to get it back on the Vag-Com
    Oct 2011
    45
    how much are these n75 valves roughly guys
    Oct 2011
    Somewhere?
    147
    i dont no, i didnt buy one, i bypasses it with a manual boost controle
    Feb 2011
    Somerset
    241
    I baught a new one from a dealer on ebay, £40 delivered and it solved all my boost probs, make sure you have the right one as some are fitted the opposite way round.
    Oct 2011
    Somewhere?
    147
    I have just ordesed the N75H valve from audi, £64 lets see if these.H valves are as good as people make them out to be. Collect it on friday
    Oct 2011
    Somewhere?
    147
    Bit of a daft question but what is the standard turbo on my s3? Some people are saying its the k03s and some say its the k04. Av always thought it was the k03s and the k04 was the upgrade most people do
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Ko4 standard
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,571
    K04 on S3's...
    <tuffty/>
    Oct 2011
    Somewhere?
    147
    Nice one, thanks lads. What do people upgrade too?
  1. BOOST PROBLEM
    By s3stew76 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2011, 19:48
  2. Boost Problem I Think Please Help :(
    By Phil_T in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2010, 07:40
  3. S3 boost problem
    By wilcog33 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2010, 20:47
  4. Boost problem
    By Lemon S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2010, 08:38
  5. RS4 B5 Boost problem
    By mattykerby01 in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 5th July 2007, 15:34
