EM TuningMonster Motorsport
Results 1 to 25 of 25
Like Tree2Likes
  • 1 Post By evotista
  • 1 Post By fingermouse
Thread: What is the recomended engine oil for S3 please
    Dec 2004
    36
    is it 10-40 or 0-40.
    Is castrol RS ok, They make 2 variations of it.
    PaulS3's Avatar
    UK
    988
    Re: What is the recomended engine oil for S3 please
    ONLY VW 503.01 spec
    on an S3 on AVS.
    even Audi have it in bold in the manual.
    It should say the spec on the back of the bottle.
    Oct 2003
    South Wales
    2,942
    Mobil 1 0-40 or Castrol SLX (not SLX2) are the favourites! Both 503.01.
    Rich.
    imported_yansgti
    [ QUOTE ]
    ONLY VW 503.01 spec
    on an S3 on AVS.
    [/ QUOTE ]
    Morning all,
    What is vw 503.01 ??!!
    Does the S3 have an oil sensor that tells you when the oil is low??? If so, does anyone rely on this instead of checking oil???
    Is the S3 known for losing any oil at all ??
    Cheers.
    Yans [img]/ubbthreads/images/graemlins/snore.gif[/img]
    Feb 2004
    Reading, Berkshire
    146
    I have posted this a number of times now - you should be able to find it by doing a search of the forum (try searching the S3 forum for "oil" [img]/ubbthreads/images/graemlins/wink.gif[/img]). Anyway, see here for a list of 503.01 approved oils.
    @Yans, VW503.01 is a VAG oil spec.
    PaulS3's Avatar
    UK
    988
    vw503.01 is an oil specificaton.
    it should be written on the bottle, of any oil you use for the s3 on avs servicing.
    yes ther is a low warning, but dont rely on it, its notoriously late in its operation.
    some s3's use alot of oil, some dont.
    imported_fingermouse
    "Does the S3 have an oil sensor that tells you when the oil is low??? If so, does anyone rely on this instead of checking oil???"
    i`d never rely on this in any car in my view if the light comes on then the damage is done.
    imported_yansgti
    sorry for repeating but, my question is that if mine is a little low and i have only just bought the car what do i put in it???? i dont want to cause damage!! help!! [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Aug 2003
    North West
    118
    As dickyS3 says just use Mobil 1 or Castrol Formula SLX ...both available at halfords both accord to 503.01 spec....don't rely on low oil check light...regularly check you oil to make sure its in the band. Also don't use Formula SLX II as this is not rated for high performance engines like that used in the S3...and quite often dealers put the giveaway 1 litre bottle of this stuff in S3 cars even though it shouldn't be used......
    JameS3rizzle likes this.
    Feb 2004
    Reading, Berkshire
    146
    I've started using Shell Helix Ultra - it's 503.01 approved AND I get PlusPoints on it.
    imported_Stewart
    What grade is VW Synta? is that ok?
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,045
    [ QUOTE ]
    [ QUOTE ]
    I was running low on oil at the weekend and thankfully topped up with Castrol SLX (503.01).
    Since topping up, I have noticed an increase in fuel economy!
    [/ QUOTE ]
    You did put the oil in the engine and not in the fuel tank? [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    [/ QUOTE ]
    Ha ha... seriously though... the Low Oil warning light came on and the engine took a whole litre of oil to get it to maximum again! [img]/ubbthreads/images/graemlins/shocked2.gif[/img]
    Oct 2003
    South Wales
    2,942
    Yeah the warning light doesn't come on until its very low. Keep a constant check on the oil levels to be on the safe side.
    Rich.
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,045
    [ QUOTE ]
    Rich.
    [/ QUOTE ]
    You're not kidding... checking fluids is now going to be part of my weekly routine!
    Oct 2003
    South Wales
    2,942
    [ QUOTE ]
    S3 SLX the one to use but from VAG as it is cheaper than Halfords.
    [/ QUOTE ]
    Or buy Mobil1 for even cheaper!
    Feb 2004
    Reading, Berkshire
    146
    [ QUOTE ]
    [/ QUOTE ]
    Yup, or buy Shell Helix Ultra and get extra PlusPoints.
    imported_oilman
    Well, according to the information that I recieved from Fuchs back in January 2005, these debates could be solved by one product that covers the new 504.00 and 507.00 specs.
    Here is some info, I'm waiting for further clarification.
    TITAN GT1 LONGLIFE III SAE 5W-30
    In addition to our previous AIS TITAN GT1 LONGLIFE III SAE 5W-30 approved by VW 504 00 and 507 00 we would like to give the following supplements.
    We would like to point out, that our new product covers all of the
    following VW-Specifications :
    - (VW 500 00)
    - (VW 501 00)
    - VW 501 01 - VW 505 00
    - VW 502 00 - VW 505 01
    - VW 503 00 - VW 506 00
    - VW 503 01 - VW 506 01
    Exception to this rule:
    For engines R5 TDI (2,5 L) and V10 TDI (5,0L) only the current VW 506 01 (TITAN Supersyn SL Longlife Plus 0W-30) is applicable.
    Conclusion:
    Our TITAN GT1 LONGLIFE III SAE 5W-30 is the ideal product for
    rationalization in your range of products.
    The 504.00 spec will cover both 503.00 and 503.01 specs as I understand it.
    Will post more when I know but this product has already been approved by VW and I've seen the German Approval documents.
    Simon
    chris039's Avatar
    S3-A quality driving experience
    Worcester
    6
    All oils are rated by API rating, the higher the letter the better the oil quality, all car manufacturers have their reccomended brands most of which only come in 1 litre bottles and at more cost. The case with mine and most S3's is common and a litre of oil will in fact last you only 600-1000 miles so the life cycle of the oil isn't long anyway. You have to ask yourself why a specific oil is reccomened and on what credits when all oils are tested before production. I get my car serviced every 10k and dont seem to have any probs.
    rpadam's Avatar
    S3 Raj
    Sep 2004
    London
    14
    Doing an oil change this weekend normally use Mobil 1 0w-40. Went down to halfords to pick some up but the back of the bottles says it doesn’t cover vw503.01 only vw502.00 and vw505.00. Would this be a problem if I still use Mobil 1?
    Facelift 2001 Audi S3 - Silver, Aluminium Mirrors, Centre Arm Rest, Sunroof, Full Black Leather, Sat Nav
    rpadam's Avatar
    S3 Raj
    Sep 2004
    London
    14
    Forgot to say Mobil 1 0W-40 previously coved vw503.01!
    Apr 2008
    122
    What's the difference between VW 503 00 and VW 503 01? And which one is S3 approved?
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    i swapped to 5w-30 as per all new audis/vw and my S3 has stopped using oil, well a little but more like a normal car i.e. very little.
    on 0w 40 i used 1/2 litre every 1-2k
    briner likes this.
    red to red black to black blue to bits
    subby's Avatar
    May 2009
    128
    Ive just serviced my facelift S3 with this:
    http://www.opieoils.co.uk/p-885-motu...productDetails
    Ester based - which is the best you can buy aparantly, but tbh everyone will have an opinion.
    1996 JDM Celica GT Four
    AviatorRichards3's Avatar
    Oct 2012
    Hertfordshire
    45
    rpadam: Yes ive just had the same problem with the Mobil 1 OW40 as it doesnt say 503.01 on the back anymore.
    Although check this out as it says ExxonMobil says its compatible with VW503.01:
    Mobil 1 New Life 0W40 Fully Synthetic Motor Oil 5L
    Mobil 1 New Life 0W-40 Fully Synthetic Engine Oil
    Si I needed an oil topup and ive called allparts and had a nice discussion about this over the phone. (also managed to get them down on their price to match that of the websites which was very nice of them.
    Once i got there, another lad who had a special interest in audi S3's said he would recommend this oil, and that yes they did change the name but its going to be fine and could even improve fuel economy very slightly over a longer period....
    So ive bought it....and ill keep you guys informed (currently getting 34 MPG) on a 2002 audi s3 8L 225 BAM
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    8 year old thread! lool
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
