Volks AutosChris Nott
    imported_Stewart
    Will 35mm offset wheels fit on the S3?
    I have my old 8x18 (35mm offset) alloys...
    I realise they probably will fit but what size spacer would i need to fill the arches perfectly?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,566
    Re: Will 35mm offset wheels fit on the S3?
    [ QUOTE ]
    [ QUOTE ]
    [ QUOTE ]
    Stewart, I am running 8.5x19" RS6's with ET30mm offset and have 15mm (rear) and 10mm (front) spacers, and the wheels sit perfectly, no fouling or protruding the arches.
    [/ QUOTE ]
    ET30 and 10mm spacers would mean ET20, that's got to be close up front Cage, what tyres are you running mate? same as me - 235/35R19??
    [/ QUOTE ]
    Yes I am running 235/35/19 tryes, I will be going 245/35/19 on rears soon.
    [/ QUOTE ]
    I'm not sure running 245s on the rear is a good idea, it would ruin the handling, but if it's for looks then why not. I think 255/30R19 is a better bet to keep the rolling radius similar to the fronts, but I avoided using different size tyre F/R to avoid any issues with the haldex system.
