AH FabricationsChris Nott
    Dec 2010
    30
    A3 rear wheel bearing replacement queries...
    The time has come to replace my n/s rear wheel bearing on my A3. Having read through the ever informative Haynes manual there's no mention of hub nut torque setting and nut size needed for my wrench. Anybody know what they might be?? has anybody come across and step by step guides on previous forums. Thanks for your interest.
    Aug 2011
    160
    The nuts will be a 30mm 12 point, some are 6 point(sided) Torque wise I´d need to check but somewhere around 80Nm sounds right.
    Audi A3 1.8T AUM Sport with more doors.
    Dec 2010
    30
    Thanks moredoor for the quick reply. just what i needed.
  1. ABS light after rear wheel bearing
    By teo420 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd July 2011, 23:12
  2. rear wheel bearing
    By FranA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th April 2011, 22:04
  3. Rear Wheel Bearing replacement.
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th February 2010, 18:22
  4. Rear Wheel Bearing?
    By mattcole2206 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th August 2009, 22:00
  5. Front Passeneger wheel bearing replacement - Any tips or guides
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th September 2005, 18:48
