Volks AutosEM Tuning
Results 1 to 19 of 19
    Sep 2009
    102
    Idle boost reading
    Can someone confirm what is the normal idle vac reading? I am currently at -0.8 bar... Does this sound like I have a leak?
    Audi A4 2.0TFSI Quattro S-line - Stock! (for now)
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,006
    Visit 16Klappe's Instagram Channel
    Just checked, mine sits at -22PSI.
    I quite often say I'm going to do things.
    Then never do them.
    Aug 2010
    bradford
    1,251
    Mine is -20
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    Sep 2009
    102
    -0.8bar = -11.6 psi.. Sounds like something is wrong...
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    I'm on -13.4. I've also been told i have a boost leak but then i've been told everything is fine? Confused.com
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    5,006
    To be fair because it is making negative pressure it will be difficult to tell if and where the boost leak is, you will need to have it vacuum and pressure tested.
    Then never do them.
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    -20 until i drive it a bit then it goes to -25 when i stop
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Jan 2009
    West London
    269
    You want around 19/20 inHg of vacuum, anything much lower would suggest a leak. Not measured in psi by the way, -20psi isn't possible.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,263
    A lot of guages show hg in vacuum not PSI. mine is around -14hg
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    S3 Paul's Avatar
    Oct 2006
    2,764
    I was beginning to think i had a problem... Mine has never seen -20 psi !
    I was told mine was "giving a good reading indicating no leaks or problems "
    I will check what it actualy reads later when i head out.
    Noggy Blue 2001 S3
    Westy's Avatar
    Dec 2008
    17,263
    I'm sure this subject has come up before and around -13-14hg was about right
    S3 Build Thread
    S3 Paul's Avatar
    Oct 2006
    2,764
    I was thinking high 'teens
    Different when still on cold start too?
    Noggy Blue 2001 S3
    Westy's Avatar
    Dec 2008
    17,263
    This is mine on cold start then it drops a bit when warm:
    S3 Build Thread
    Aug 2010
    bradford
    1,251
    When mine starts (cold) it's 12 psi ish then when warmed it goes to 20 psi
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Mine is -20 in.Hg
    Looking at most boost gauges
    Vacuum - in.Hg
    Boost (positive pressure) - PSI
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    It all depends on the calibration of the guages i mean pay 20 quid for a guage you are hardly going to have lab results.....
    Andy123 is correct, it is shown in HG not psi and all the forced induction cars ive had, it has always shown around the 20 in hg mark on idle, infact i used to use this as a tool if it went closer to 10 in hg, i new i had a leak somewhere, and sure enough there was one...
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,221
    Mines around the 20 mark.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,420
    -20hg
    S3 Paul's Avatar
    Oct 2006
    2,764
    Mine sits at about -18 once warm, Goes up ( or down ) to -22 on over run,
    Noggy Blue 2001 S3
  1. What does your boost gauge read on idle? Think i got a leak...
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2011, 17:22
  2. Boost Gauge Reading??
    By A3 T in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2011, 15:27
  3. boost gauge reading
    By steve bain in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2011, 21:27
  4. VCDS reading not matching up with DIS reading!
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2009, 22:05
