Sky InsuranceEM Tuning
Thread: fault codes
    Jul 2011
    169
    fault codes
    have had these faults show up on vcds can anyone shed any light what they mean
    VCDS-Lite Version: Release 1.0
    Tuesday, 04 October 2011, 10:19:31.
    Control Module Part Number: 06A 906 018 AQ
    Component and/or Version: 1.8L R4/5VT MOTR HS D04
    Software Coding: 04000
    Work Shop Code: WSC 06313
    1 Fault Found:
    16989 - Internal Control Module: ROM Error
    P0605 - 35-00 - -
    Tuesday, 04 October 2011, 10:22:27.
    Control Module Part Number: 8L0 959 655 F
    Component and/or Version: Airbag 7 Audi 0505
    Software Coding: 00104
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    The weapon of choice... The a3
    got an S3 8L: living the dream
    Mar 2010
    Kent
    173
    I am no diagnositc expert but maybe this will point you in a right direction?:
    http://wiki.ross-tech.com/wiki/index...9/P0605/001541
    00532 - Ross-Tech Wiki
    2002 S3 8L AMK
  1. help with 1.8t fault codes please
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2010, 20:59
  2. Fault codes
    By MPP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th June 2010, 17:53
  3. How can i fix these fault codes
    By just017 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th July 2009, 21:00
  4. VAG COM fault codes - help please?
    By Geeman in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th June 2009, 08:54
  5. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
