Chris NottAH Fabrications
    Oct 2011
    audi 1.8 t 2001 quattro buying advice
    i im after some advice. I am looking to buy an audi a3 1.8t 2001, I have looked at one that has a few problems and wonder if anyone could confirm if these are common faults and easy to get repaired or if they are anything of real concern.
    1. appears to have a small oil leak from the back of the sump possibly from thep plug. Is this a common fault as there is a lot of post on the net about this, is it an easy repair.
    1. the traction light remains on even when you try and turn if off?
    1. should the oil lamp come on when you turn the ignition on or does this only come on if there is a problem with the car? As this does not come on when you first start up (every car ive ever had has the light come on when u first car to indicate this is working)
    1. the cam belt has been changed but the water pump hasn’t how much approximately will it cost to have these done?
    any comments/advice would be very much appreciated
    S4 Muzza's Avatar
    oww! my giant blue head!
    May 2011
    Ayrshire
    299
    The oil leak shouldnt be too big a deal if its just the sump. If a new plug doesnt solve it you probably just need to re-seal it, £20 for the stuff and a few hours of your time.
    From memory the oil light only comes on if theres a problem, not sure about your other queries.
    To be honest mate unless you're getting a good price i'd just leave, theres plenty out there that wont need as much/anything doing!
    Audi S4 (B5) - JUST ARRIVED :D
    Audi S3 (8L) - GONE
    Audi A3 SE (8L) - GONE
    Oct 2011
    Thanks for the reply.
    I think I'm getting a good price for the car it's done 84,000 and the problems above are all i can see wrong and I've managed to get him down to 1800 quid so I can afford to spend a bit on the car
    Any more advice on the above would be welcome
  1. Buying Advice: 2006 A4 1.8T Quattro
    By Mr1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th November 2010, 12:10
  2. 2.0 tfsi quattro buying advice, general advice please
    By ti_172 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th May 2009, 20:50
  3. first post - A3 3.2 Quattro DSG buying advice
    By ml in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th October 2008, 10:55
  4. A6 4.2 Quattro Buying Advice
    By Ben9377 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 6th April 2008, 19:39
  5. Contemplating buying a 2000-2001 TT Need Advice
    By stormchaserx in forum TT/TT-S/TT-RS Forum
    Last Post: 11th January 2005, 14:11
